rev limit and fuel cut questions?
Old Aug 18, 2002 | 06:46 PM
PM-Performance's Avatar
Default rev limit and fuel cut questions?
ok well after changing to aftermarket ignition and tach . i dont knwo what to do to make sure all is accurate. i set the rev limit on the msd to 8500i think . and it looks like to me that the tach is now reading like 8100-8200 when the rev l;imit kicks.
is my msd settings reading the actual engine rpm , or can it be off like thestock tachs are. ? i noticed my stock tach is only off in reall high rpms.
im thinking im gonna take off the rev limit on the msd and jump on it just to see wherre actual fuel cut reads now on my autometer , and then eqaute from what it should be anbd make the mathematical changes to my settings to make them match up and get all my power and not have it cut to early and not cut too late and blow my motor.
i want to set the msd limit to 100 rpm,s before factory fuel cut.
Now is the factory fuel cut at 8600? or 8500? i thought it was 8600 off hand , but wanna make sure.
thanks for the help in advance, and sorry for the long post.
[Modified by itr206, 8:07 PM 8/18/2002]
Old Aug 18, 2002 | 09:18 PM
Incognito's Avatar
Default Re: rev limit and fuel cut questions? (itr206)
Which tach is reading 8100/8200 when rev limiter kicks in? Stock, or Autometer?
I'm pretty sure the stock limiter is at 8600rpms.
The MSD and Autometer tach should both be dead on.
No matter what, don't hit fuel cut when you're spraying.
Good luck.
.... U running the thing at E Town this weekend?
Old Aug 18, 2002 | 09:30 PM
B2FiNiTY's Avatar
Should be kicking in at 8600. The stock tocks are really off and Iused to be able to hit 9.1K before it kicked in.
Old Aug 19, 2002 | 03:40 AM
Default Re: rev limit and fuel cut questions? (B2FiNiTY)
the autometer was reading 8200 or so when shutting off. ? maybe its just getting up that quck that i cant see it ?
i have the shift light set at8k , that comes on and it seems instantaneously it then shuts down?
maybe its just getting there quicker then usual and im slowing my reactions down?
hondacummins
Engine Management and Tuning
12
Jul 20, 2014 08:14 PM
hi-Powered
May 16, 2005 09:56 PM
C_I_V_I_C
Apr 23, 2004 09:50 AM
LshatchTurbo
Jan 15, 2002 06:06 AM
Black R
Jul 25, 2001 12:46 PM
