Feeling the Vibration
Old May 19, 2009 | 07:00 AM
Cmy4gD's Avatar
Default Feeling the Vibration
what's up. i am having a problem with vibration around the pedals and the front of my car. i just put a gsr in my 99 si and it seems to be vibrating more than usual. what could be the problem and what are my options? also i am trying to pass emissions so how many o2 sensors do i need to have hooked up?
Old May 19, 2009 | 07:12 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Feeling the Vibration
yes you need them hooked up. if you dont your car wont run as good either. vibration could be that your motor mounts are pretty stiff. get used to it, it feels good
Old May 19, 2009 | 07:31 AM
lponcian5799's Avatar
motor mounts x2
did you use the same ob2 ecu?
Old May 19, 2009 | 09:29 AM
Cmy4gD's Avatar
i kept the ecu for the b16. how many o2 sensors am i going to need though? and the motor mounts are stock and brand new...so is this vibration just something that will go away once the mounts are "broken in"?
Old May 19, 2009 | 10:29 AM
geneeunit's Avatar
you're going to need a GSR's ecu..
Old May 19, 2009 | 12:11 PM
Cmy4gD's Avatar
what do i need a gsr ecu for?
Old May 19, 2009 | 12:21 PM
trustdestruction's Avatar
for your GSR engine...
Old May 19, 2009 | 12:33 PM
Cmy4gD's Avatar
its running with the b16 ecu fine though so what's the point?
Old May 19, 2009 | 01:07 PM
With a B16 ECU how is your secondary butterfly working? Also, the B16 ECU is for a B16, not a B18. The B16 ECU is made to run on an engine with a different stroke, deck height, compression ratio, displacement, etc. It's plain and simple, the B16 ECU is not designed to run a B18C1.
It's running "fine" of course, but if all you are satisfied with is that it's running and don't care that it's not running optimally, why did you even swap the engine?
Do it right, or don't do it at all.
Old May 19, 2009 | 04:31 PM
geneeunit's Avatar
thank you.
ctreg6
Jan 25, 2008 08:07 PM
fastest_ex
Jun 29, 2005 09:49 AM
matto2413
May 10, 2005 01:27 PM
XEF-9X
Jul 20, 2002 10:04 AM
