97 accord smoking :( help!!!
Old May 18, 2009 | 11:02 PM
mayfly's Avatar
Default 97 accord smoking :( help!!!
i have a 97 accord 4 door automatic. it runs fine. but it is smoking under the hood. its not like alot of smoke but i pop the hood and air it out everytime i park it. the smoke is coming from the back fire wall, like the intake manifold and around there. i cant really tell where its coming from. does anyone know what the problem might be? thanks everyone
Old May 18, 2009 | 11:27 PM
h22 kid's Avatar
Default Re: 97 accord smoking :( help!!!
having the same problem... i think its the rear hose in the back of the block... try checking that
Old May 19, 2009 | 06:03 AM
TheMuffinMan's Avatar
He knows where you live!
It could just be an exhaust leak - mine will do this on occasion.
Old May 19, 2009 | 09:41 AM
mayfly's Avatar
is it possiable that the gasket on the intake is bad?
Old May 19, 2009 | 10:05 AM
tougetuned_ef's Avatar
i would get down there with a light and make sure there are no fluids leaking from a sensor or coolant hose. i had a small crack on a hose on my intake and all i could see was smoke coming out from my hood. also, start car and use the tb to rev the the motor and watch the smoke as you rev it. if the smoke dissapears when it is done it is prolly an exhaust leak. the force of the exhaust will push it right past the leak but when it sits idle is kinda sit there and leaks out.
Old May 19, 2009 | 05:47 PM
h22 kid's Avatar
well for a fact i know mine is water because it starts to boil and bubble and water falls to the floor and later it disappeared.... idk if its my hose or what? i'll get to it later lol... gl to the other guy in what it could be
Old May 19, 2009 | 06:02 PM
whitewonder's Avatar
are you losing any ammount of coolant ?? there are coolant lines that go to your iacv on the back of throttle boddy could be leaking.
did you just have oil chage ? they could have been sloppy and spillt some.
Old May 19, 2009 | 09:19 PM
mayfly's Avatar
i did just have the oil changed. i usally change it but had a shop do it for me. and thanx to everyone for the help. and tougetuned_ef imma try ur trick tommorow in the day light. thanks everyone
Old May 20, 2009 | 03:31 PM
Then if u just got ur oil changed they prolly did a sloppy job and it rann all over your block.
Changing oil on honda accord is a very EAZYoil change compared to others.
but the placement on the engine is slightly angled up so it will drip onto the block if ur not quick about thinkgs.
spend the extra dollar and get a wixx or fram filter or something along them lines. should be less then 8 dollars for a filter if u do it yourself then w/e brand of oil u use 6-7 quarts -
good oil filters will hold alot of oil then them themself normaly 1-2 quarts n always good to prefill them, but also can get sloppy when u try to put on :-p
Old May 20, 2009 | 04:54 PM
GhostAccord's Avatar
x2 on the sloppy oil change. The exhuast is directly under the oil filter. they probably spilled oil onto the exhaust pipe when they removed the filter and didn't clean it off. Or they may have doubled up on the oil fitler gasket, this can cause a poor seal and small amounts of oil will drip from your filter. check that while your checking the block and sensors for leaks.
Old May 20, 2009 | 06:23 PM
statik215's Avatar
Yo your avator is nice!
nichxestes
Oct 11, 2013 05:12 PM
integracecraft
Jun 20, 2013 10:23 PM
DH850T
Feb 9, 2010 06:05 AM
Fantastic420
Nov 18, 2009 03:28 PM
dleccord
May 18, 2008 07:54 AM
