View Poll Results: Which head on b20 block?
B16a2 head
52.81%
B18c1 head
47.19%
Voters: 89. You may not vote on this poll
Which head is better?
Old May 18, 2009 | 06:39 PM
JWhip1's Avatar
Default Which head is better?
im looking to start building a b20vtec motor and wondering which head would be better a b16 head or b18(gsr) head. Have some time before i start so gimme your thoughts
thanks
Old May 18, 2009 | 07:17 PM
taggart_lumpy's Avatar
Default Re: Which head is better?
i opted for the b16 head
Old May 18, 2009 | 07:22 PM
R666_EK's Avatar
Well. I say go for whatever you can get a better deal on. If you are leaving it stock then its a toss up. B16a = slightly better flow B18c = slightly better cams.
So its up to you. If you plan on doing some porting and building it doesn't really matter that much.
Old May 18, 2009 | 08:44 PM
P12 EG6's Avatar
heres the thing , if your using a stock B20 block i would suggest the B18C1 head because it has a smaller combustion chamber than the b16(p30) if your gonna port and build the head then it dont matter that much.. and eather way dont run stock cams you need more lift and duration for the displacement
Old May 18, 2009 | 09:48 PM
Deetz's Avatar
Crazy Honda Guy
NEITHER is better. One has a couple hp on the lower rpm, one has a couple more on the higher.....is the power noticable between them? NO
Old May 18, 2009 | 11:58 PM
eggsi619's Avatar
ownned! hahah
Old May 19, 2009 | 10:25 AM
rick_rabies's Avatar
I'm not Rick!
b16 is for NA, the gsr head makes more of a swirl when taking in air...better for turbo.
Old May 19, 2009 | 11:09 AM
siguy44's Avatar
I call bs on this guy.
-=*javy*=-'s Avatar
b16 better airflow
gsr .5 compression
you have the graph to see the difference between the too
Old May 19, 2009 | 11:15 AM
seadonkeyraypiss's Avatar
Because the gsr head was designed for a turbo application right?
Old May 19, 2009 | 11:30 AM
I'm not Rick!
for the iabs. its from honda, the flow rating. look it up
Old May 19, 2009 | 11:32 AM
I'm not Rick!
mister siguy i think you will disagree you when you take a ride in the whip when its done.....taylor
Old May 19, 2009 | 11:58 AM
Snafubmx234's Avatar
IABS was developed as Honda's stab at variable length intake runners. Please enlighten us all with how this creates a "swirl" and how that "swirl" is better for a turbocharged application. Speculation? I think so.
Old May 19, 2009 | 12:19 PM
I'm not Rick!
i read it a ways back...look it up. your speculating im wrong. i might be, then so is honda.
Old May 19, 2009 | 12:21 PM
I'm not Rick!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b16-head-vs-b18-head-469492/
Old May 19, 2009 | 12:24 PM
calm down there pal
Old May 19, 2009 | 12:25 PM
I'm not Rick!
i was just enlightening the fella, is it my avatar that scares them?
Old May 19, 2009 | 12:27 PM
RyanA's Avatar
I've always said any head is good head. I agree that whichever one you can get your hands on at a more reasonable price is the one to go with. I've used both with great results...
Old May 19, 2009 | 12:32 PM
Top Speed's Avatar
This topic has been gone over way to many times.
Old May 19, 2009 | 01:01 PM
alexsan's Avatar
X2...
B16A2 Engine....160hp
B18C1 Engine....170hp
B16A2 best performance head, best cams
Old May 19, 2009 | 01:52 PM
stealth50k's Avatar
B18c1 head is taller so it would look bigger when you show off your beast . Both are practically the same in flow from the charts. Just use whatever you can get.
Old May 19, 2009 | 02:28 PM
Deetz's Avatar
Crazy Honda Guy
OMG!!!!!! LOL, wow, thats untrue!
Old May 19, 2009 | 02:29 PM
TypeRMOBBiN209's Avatar
b16 head!!
Old May 19, 2009 | 02:37 PM
99civicsiguy's Avatar
b16a2, hasn't failed me yet
Old May 19, 2009 | 03:01 PM
yes SiR's Avatar
just go with the one that you can get a deal on and is in better condition
