gsr brakes swap
Old May 18, 2009 | 04:50 PM
jerry_ort007's Avatar
Default gsr brakes swap
i got my hands on a set of gsr brakes to swap it onto my ej2 but the setup is missing a few pieces. i was wondering if some parts from the ej2 disc/drums would fit the gsr setup (e.g. nuts, bolts, hubs, etc.) or would i have to get them from the same gsr setup?
any info would be appreciated, tanks.
Old May 18, 2009 | 05:51 PM
omgwtfbbq's Avatar
Default Re: gsr brakes swap
you need the knuckles, rotors, calipers, LCAs, ebrake cables, proportioning valve, and booster from a GSR for it all to work. that is, if you are doing a drum to all wheel disc conversion.
Some will say that the valve and booster arent necessary....but since we are talking brakes, you don't want to half *** it. I'm sure your insurance company wouldnt like it if you slammed into someones car because your brakes, that you installed, failed.
Old May 18, 2009 | 07:55 PM
SOHCNightmare's Avatar
i ran around without the proper prop. valve for a long time. the right one being a "4040"
and it just didnt feel right.
i swapped it... and it feels amazing now. so do it all right the first time!
Old May 19, 2009 | 09:20 PM
thanks for the info, but i already know what i need to do the drum to disc conversion. but what i would like to know is if the hubs from the drum assembly would work fine on the disc assembly being that they are both the same bolt pattern; or would i have to get the everything from a gsr?
Old May 20, 2009 | 01:55 AM
94EG8's Avatar
Seagull Management
You need the hubs from an '88 - '00 civic or '90 - '01 Integra with rear disc brakes.
Old May 20, 2009 | 03:39 PM
thanks... thats what i needed to know before i start taking things apart.
Tenzo
Suspension & Brakes
Aug 24, 2012 04:39 PM
OEMJDM
Suspension & Brakes
Feb 10, 2010 07:06 PM
bradpee
Mar 25, 2009 10:58 AM
TedR719
Jun 23, 2004 11:08 AM
