Clutch Hydraulic Fluid Location???
Just recently my clutch has started to lose pressure, however its still engaging at the right time. It leads me to believe it could be a leak or just lack of fluid in the hydraulic system linked to the clutch.
I have a 97 hatch with a gsr, i was wondering if anyone could direct where to look for this reservoir. If you have any additional information, that would rock! thanks
The clutch fluid reservoir is to the immediate right of the brake fluid reservoir in your picture.
Check for a leak from the master cylinder near the firewall and above the clutch pedal, as well as at the slave cylinder located straight down from the distributor.
hondaless
Apr 2, 2009 08:58 AM
afropuffs808
May 2, 2008 06:17 AM
