Cluster,Speedo, Engine Temp, tach and turn signals not working!?!?
Old May 18, 2009 | 01:21 PM
Ran4it2's Avatar
Default Cluster,Speedo, Engine Temp, tach and turn signals not working!?!?
I was leaving my house today and all of a sudden my cluster just went out
clock doesnt work nor does everything i mentioned above
the light comes on and everything but im not sure
i checked fuses. and im pretty sure its not unplugged cause the lights and the high beam light work
what could it be?
Old May 18, 2009 | 04:46 PM
eros18's Avatar
Default Re: Cluster,Speedo, Engine Temp, tach and turn signals not working!?!?
im just guessing here, but it could be the dimmer switch.
correct me if im wrong with this.
Old May 18, 2009 | 08:11 PM
Ran4it2's Avatar
i'll check that but i highly doubt it
the light comes on
Old May 18, 2009 | 09:47 PM
eros18's Avatar
my bad, i thought the lights were not working.
Old May 18, 2009 | 10:06 PM
94wip's Avatar
you've got lights but no turn signals? If so, it could be a worn out multi function switch. My signals went out and it was due to that. Not sure aboutt he cluster though, good luck
Old May 18, 2009 | 10:08 PM
patrick_101_'s Avatar
i would double check the fuses .......got pulled over when the speedometer,turn signals ,everthing on the instrament pannel went out...it took three times of trying to track it down...sorry i don't have any other ideas to what it might be.......
Old May 18, 2009 | 10:14 PM
Ran4it2's Avatar
figured it out
it was a blown back up light fuse
so simple yet it made everything go bad
now if anyone encounters this problem they know what is it
chriszal1
Jun 16, 2011 08:19 AM
mudd_butt
Oct 17, 2008 07:56 PM
spooncivic1
Dec 7, 2006 08:53 PM
EkREV
Sep 19, 2005 09:01 PM
EGTeK
Mar 26, 2003 10:52 AM
