16" Type-S Rims with TIRES (Bay Area, CA)
WHEEL/RIM info:
- selling a used set 2002-2004 Acura RSX Type-S OEM/Factory Rims
- size is 16x6.5
- offset is +45
- Bolt pattern: 5X114.3 (means 5 lugs spaced 114.3mm apart)
- Lug nut size: 12mm X 1.5" (12mm thread size by 1.5 inces long)
- they come with OEM "A" centercaps
- rims are in good condition (some minor/light curbs)
- NO bends of cracks on the rims
TIRE info:
- Sumitomo Ultra High Performance HTR Z
- Tire Size: 205/55/16
- Load Index: 90w
- Design Rim Width (inch): 6.00
- Rim Range (inch): 5.5-7.5
- Single Max I.P. (psi): 44
- Single Max Load (lbs): 1.235
- Ovaerall Diameter (inch): 24.9
- Section Width (inch): 8.2
- Tread Width (inch): 7.2
- Tread Depth (X/32"): 10.0
- Static Loaded Radius (inch): 11.5
- Rolling Circumference (inch): 75.6
- Revs Per Mile: 838
- Tire Weight (lbs): 22.4
- 2 TIRES are 75% & the other 2 are 60%
- 2 TIRES have some very minor camber wear & the 2 is completely even wear...
- SOLD!
ACTUAL PICTURES BELOW...
- size is 16x6.5
- offset is +45
TIRE info:
- Load Index: 90w
- HTRZ offers excellent handling at high speeds, and superb wet and dry traction
- V-Shaped Directional Tread – Quickly disperses water providing superb wet grip and traction
- Four, Deep, Wide Circumferential Tread Grooves – With two additional inner circumferential grooves provide excellent anti-hydroplaning performance
- Large Angular Shoulder Blocks – Enhance steering response and overall dry grip
- Triple Tread Radius – Provides optimum performance footprint for maximum traction
- Center Rib – Enhances straight-line stability
- Sidewall Stiffeners – Improve steering response and overall handling without sacrificing ride comfort
- SOLD!
cozmo2312
Aug 14, 2003 09:38 PM
