need help. plz?
Old May 18, 2009 | 04:06 AM
grod925's Avatar
Default need help. plz?
so i have a 93 accord ex.(f22a6) i recently put on some headers and ive been having problems since then.
ive been hearing this kinda loud (not too loud but noticeable) grinding noise coming from thefront. i checked if the headers or the down pipe were rubbing on something but no sign of anything.
so i pretty much checked everything i could think of and the grinding noise still remains,
im concerned i messed up something in the head, or engine...
any ideas what it could be?
thanks
Old May 18, 2009 | 04:30 AM
GhostAccord's Avatar
Default Re: need help. plz?
Unless you dropped one of the exhuast studs or nuts down into the head. Putting on a header won't cause any harm to your engine or disrupt anything that would start grinding.
When do you hear the grinding noise, All the time, or only when you are driving?
If it is doing it all the time you should be able to pinpoint where the noise is coming. Start the car, let it idle and open up the hood. See if you can track down where it is coming from.
Can you take a short video of it and post it? It will give people a better idea of what your hearing.
Old May 18, 2009 | 04:43 AM
stang7043's Avatar
Did you have to move the alternator or ac condenser to get the old exhaust manifold/heat shield out ?
Old May 18, 2009 | 04:48 AM
grod925's Avatar
i didnt have to take off any other parts when i put em on. i even took off the headers again and made sure eveything was in place.
and the only time i hear the noise is when i accelerate.
Old May 18, 2009 | 04:49 AM
grod925's Avatar
and yea ill try to get a video up
cuz its kinda hard to explain i guess haha
Old May 18, 2009 | 04:52 AM
stang7043's Avatar
Accelerate while moving or just when you throttle up ?
Old May 18, 2009 | 04:56 AM
grod925's Avatar
accelerate while moving
i also checked the front axles or whatever theyre called, and theyre fine.
Old May 18, 2009 | 05:14 AM
stang7043's Avatar
Can you tell if its coming from the engine compartment or the front end ?
Old May 18, 2009 | 05:16 AM
grod925's Avatar
im pretty sure its coming from the engine compartment.
Old May 18, 2009 | 05:33 AM
Are you hearing a very quick, kind of raspy ticking? If it is then that is the sound thin walled steel headers make under acceleration. Vs the quiet of the thick cast iron walls of the OEM exhaust manifold. If you really want to be sure you could put your OEM manifold back on and see if the "grinding" noise goes away.
Old May 18, 2009 | 06:41 AM
grod925's Avatar
yea it does sound something like that.
i can give that a try and see if it works
ill keep you updated haha
Old May 18, 2009 | 08:34 PM
grod925's Avatar
problem solved
thanks
Old May 19, 2009 | 05:32 AM
EK45VTi
15
May 2, 2007 10:16 PM
hmongshaa
Honda Civic (2001 - 2005)
20
Apr 22, 2007 03:16 PM
makri
Feb 3, 2006 09:03 AM
banshee65
Jun 30, 2005 03:05 PM
