D16A (z6) into 97 Dx Questions...
my stock d16y7 is soon to blow... will a d16a (basically a d16a6 but with vtec, better terms : d16z6) be direct bolt up as far as wiring goes?? questions:
1) Would it be easier to run y7 intake manifold or the D16A manifold? as far as wiring for the plugs etc? are they direct plug & play or are there differences?? also have available a d16a6 intake mani/tb if that helps at all...
2) distributor : for the time being, i would plan on running my stock y7 dist and just having a vtec controller. would i have any problems as far as the firing etc??
3) clutch/flywheel, im currently runnin an 95dx trans on my y7 (its still hydrolic etc...) would the clutch and flywheel from an 89 crx si work?? is there a way to tell for sure??
4) fuel rail and injectors : would i just run my stock injectors and fuel rail or the ones of the d16a??
any input is very very much appreciated... im sure will have more questions along the way, but im planning on really diving into it later this week... thanks!
Cozmikk
Nov 3, 2017 12:35 PM
Cozmikk
Nov 2, 2017 03:19 PM
AJxr
Jun 3, 2007 07:21 PM
