try to find out which wire is what on the plugs on the back of the guages
im trying to find out what the wires r on the back of a 90 gauges.
i found a few thing on here but never able to find all of it, like on the 8pin connector there a blue/red wire that i dont know what is, and then i dont know what the wire go to on the light blue 5 pin connector is either
i put this together sometime ago when i did a cluster swap. should help you figure it out. its been so long i cant recall what the blue connector was used for though.
ive got everything from the two gray connectors but the 8pin theres one wire i dont know which is blue/red, i think its like pin 4 i dont have it in front of me so not sure, and then i need to know what the blue connector is, if anyone knows a site to go to that would give me all the connectors or something like that let me know. thanks
blue/red at pin A4 is the driver's seat belt reminder light
the 5-pin connector is the 'D' connector:
D1 - red/black - from light switch (CRX HF only)
D2 - red - from dimmer control (CRX HF only)
D3 - yellow/black - to automatic seat belt control unit
D4 - yellow - power
D5 - green/yellow - economy driving indicator light from ECU (CRX HF only)
D4 - yellow - power
Mac Listo
Apr 22, 2008 06:03 PM
BLUE EH3
Aug 25, 2004 04:39 PM
I8ayellowcrayon
May 24, 2004 08:21 PM
