Suspension & Brakes Theory, alignment, spring rates....
rx7 calipers on our cars??????
Old May 17, 2009 | 08:03 PM
h_block88's Avatar
Default rx7 calipers on our cars??????
This is what i am trying to do i am looking for a big brake kit for my eg6 for so long.I have gsr rear dicks, master cly, and front brakes but i am trying to get something better and somewhat cheap.
I tryed to do rl 4 pot but its too hard to get the calipers and too pricey.
Did anybody tryed rx7's on there cars i know they ll work with somewhat a breaket but if anybody did i need some advice..
Old May 18, 2009 | 11:11 AM
racebum's Avatar
Default Re: rx7 calipers on our cars??????
the pbr twin piston from the 89-96 corvette is another that's extremely light and has a similar bracket mount. the only thing you run into with these is the possible need for a 2pc rotor and a hat that sets the offset correctly for your car. since the vette brakes are all PBR/BAER you can probably get the correct rotor from baer and if you really need to a custom top hat. i think, and i mean think that baer makes a brake kit for the teg & if they do the rotors could be bought while you fab up mounts for the vette calipers. also, the non grand sport cars have plain calipers. only the GS and later c5 body have corvette written on the caliper.
Old May 19, 2009 | 07:31 AM
h_block88's Avatar
i see but but did any body tried any of these calipers
Old May 23, 2009 | 11:31 AM
FIGARILA's Avatar
Assuming your talking about the 4 piston aluminum ones, Yes i did. I ended up selling them cause they required machine work to properly fit them. Also, they don't take a banjo bolt directly to the caliper. So you have to use rear drum brake lines to connect them to the vehicle.
Old May 26, 2009 | 03:25 AM
Dee's Avatar
Dee
There are a couple shops here in Japan that make FC3S/FD3S RX-7 and Nissan 4 pot caliper kits for Hondas. I'll try to find some pics tomorrow but I do believe they are redrilling the RX-7 caliper mounts and adding spacers. The Nissan calipers' mount ears are shaved a custom bracket is utilized to mount the calipers. I have the SS Works R32 Skyline caliper/S2000 300mm rotor kit on my DC2. It requires a +25 to +35 wheel (TE37, CE28, Buddy Club P1, CP-035, etc..) for clearance of you are using a 15" wheel.
Old May 26, 2009 | 06:37 AM
RedR's Avatar
dee,
Whats the price of that kit? are u aware if it fits the jdm 16 inch itr wheels?
Couldnt find any info of it in teh net
Old May 26, 2009 | 11:49 AM
racebum's Avatar
just curious, but is there a reason you're overlooking the wilwood kit? even with shipping to europe it's a direct bolt on affair and affordable.
Old May 27, 2009 | 12:23 AM
Dee's Avatar
Dee
Originally Posted by RedR
dee,
JDM ITR wheels are the wrong offset so you will have to add a spacer. I should have said... 7-8" wheel require an offset of +25 to +35 depending on the wheel design. The Nissan kit sold for $1300 and I sometimes see used and new kits on Yahoo Auction. If you had a 4 lug setup I'd sell you mine because my center locks are not compatible with it. The Mazda caliper upgrade is used with OEM sized rotors. I will dig through my work laptop for pics after I get home because I am leaving right now.
SS Works wheel compatibility:
TE37 15x7 +35
TE37 15x7 +43 (need to add a 5mm spacer for caliper clearance)
SSR Type C 15x7 +30
SSR Type C 15x7 +35 (need to add a 5mm spacer for caliper clearance)
Buddy Club P1 15x7 +38
Regamaster 15x7 +35
A few of the Japanese guys run 7.5" rims with +25~+35 offsets (CE28, CP-035, ADVAN RG, etc...)
Oh yeah, I'd go with the Wilwoods if I were you!
Old May 27, 2009 | 12:05 PM
RedR's Avatar
been in touch with brian from fastbrakes and it seems none of his kits will fit the jdm itr wheels....unless i´d run the regular willwood kit which hasnt had that great reviews.
I´ve been following a topic regarding the rx7 caliper conversion on the european itr site but there hasnt been much progress so far lol
Old May 30, 2009 | 07:49 AM
dparm's Avatar
New User
Why are RX-7 calipers so special? There's a gazillion other kits that install much more easily and offer the same performance.
Old Jun 2, 2009 | 09:27 AM
FIGARILA's Avatar
well i can get 4 pot aluminum calipers off of 80's RX7's for like $40 a pair at my local pick-a-part. That's why they seem so appealing to some people.
Old Jun 5, 2009 | 04:51 AM
h_block88's Avatar
there are really cheap for what you get and better calipers then wilwood
Old Jun 5, 2009 | 04:53 AM
h_block88's Avatar
i have team dynamics 4x114 with 38 offset and i am puting 15mm 4x100 adptors so i ll have
+23 offset i just need to know how to put them on
Old Jun 7, 2009 | 03:42 PM
Dogginator's Avatar
Daisy... Daisy...
What is the disk diameter for the RX7 calipers in question?
Old Jun 7, 2009 | 05:03 PM
jasoncanseeoh's Avatar
Wait, you have gsr rear DICKS on your eg?
Am I the only one that caught that? LMAO.
Old Jun 8, 2009 | 03:26 PM
h_block88's Avatar
lol you know what i mean
drSquish
Jul 18, 2006 09:22 AM
idriveadelsol7
Jul 30, 2005 09:36 AM
ef-sihatch
Nov 21, 2004 06:56 AM
ChiBoy
Feb 1, 2002 06:05 PM
