Do i need camber kit for coilovers ?
Old May 17, 2009 | 06:53 PM
krysted9354's Avatar
Default Do i need camber kit for coilovers ?
ok i just want to lower my civic 1.5-2.5 inches with skunk coilovers on stock shock, do i need a camber kit for that ? and that on stock wheels ?
also if i install rear lower control arms aftermarket will i neeed a camber kit ?
thankyou
Old May 17, 2009 | 07:11 PM
rSol93's Avatar
Default Re: Do i need camber kit for coilovers ?
Might want to invest in some shocks before you buy a camber kit and LCA's. Those coilover sleeves will blow the stock shocks.
Old May 17, 2009 | 07:16 PM
i know, i have some tokios
Old May 17, 2009 | 07:19 PM
Warhawk's Avatar
no you do not need a camber kit. Just get a good alignment and you will be set.
However, I DO NOT suggest putting coilover sleeves on stock shocks. Your stock shock absorbers will blow out in no time and the car will be dangerous to drive until you replace them with something better. I would suggest tokico illuminas if you can afford them.
Old May 17, 2009 | 07:35 PM
ok so even if i put aftermarket skunk2 rear lower control arms i still dont need camber kit ?
Old May 18, 2009 | 11:44 AM
ok anybody have a 2" drop picture of civic eg ?
Old May 18, 2009 | 02:10 PM
98civdx's Avatar
Master Detailer
NO you dont need a camber kit, just alingnment.
no if you put rear lcas in it wont change anything
but i wouldnt get an alingment intill you put the lcas in and let the car settle for a week.
Old May 19, 2009 | 12:11 PM
ok sounds good, but also if im broke for the summer because of my motor build, but i have new civic si 2000 struts ,are they stronger and better to use ? will they fit ?
also will integra stock struts fit and if so are they better for lowering ?
Old May 19, 2009 | 12:23 PM
trustdestruction's Avatar
Toe is key. A little bit of negative camber is only going to take a few miles off the life of the tires, making a camber kit not worth buying. Having a bad toe setting is what destroys tires. Get an alignment and toe set to 0 and you'll be fine.
2000 Civic Si struts will not fit. The bracket at the bottom of the shock is too wide. The front will "fit" but there's something different about the brake line mounts.
94-01 Integra shocks/struts will fit.
However, neither of these is going to be good for lowering.
If you're too broke to buy shocks then you need to just leave the car at stock height.
Old May 19, 2009 | 12:41 PM
yoontim23's Avatar
You don't need a camber kit for any of those mod's. A alingnment might do you some good after you lower it though.
Old May 19, 2009 | 12:51 PM
redlinetuning's Avatar
Right: Toe settings are key factors to tire wear. Camber settings aren't up to a certain degree.
wrong: 2000 Si struts are the same as all others. It's only the forks and front lower control arms that are different from all the other civics. I have a 98 civic dx with 2000 si forks and lca's and front anti-sway bar.
but to answer the OP's questions, stock struts are stock struts. You'll blow them if you go too low.
To the poster who said you should "wait a week for the suspension to settle", that's false too. What you should do is tighten all the suspension nuts/bolts down, then lower the car from the jack/stands, then torque the nuts and bolts, especially with anti-sway bars, tie bars, and new lower control arms. Pre-loading before you torque the bolts are more important.
Old May 19, 2009 | 12:59 PM
wrong: the OP has an EG, not an EK. 92-95 struts/shocks are different from 96-00 struts/shocks. Like I said, the struts will "fit", but the brake line brackets are different or not even there, I don't remember which. The shocks have narrower forks at the bottom and to use them on a 92-95 Civic you have to file down the LCA bushing or use a 96-00 LCA bushing. For the record, when I say struts, that is the fronts I am talking about, and when I say shocks that is the rear.
Old May 19, 2009 | 01:15 PM
alexsan's Avatar
f the camber is > -1.5 then install Camber kit...it is recommended change the shocks...tokico illumina, KYB AGX, Bilstein..etc
Old May 19, 2009 | 01:18 PM
psh, you can get away with way more than that.
I know a guy who used to have a 92-95 coupe slammed with -3º camber and no camber kit. Got an alignment and had the toe set to zero. He had very, very minimal uneven tire wear.
Old May 19, 2009 | 02:22 PM
98civdx's Avatar
Master Detailer
wrong.
1.5 isnt that much compared to how much others have my friend has -3.0 on his eg and his tires are doing good.
krysted9354
Suspension & Brakes
May 18, 2009 12:49 PM
exratedaccord93
Sep 8, 2006 06:32 AM
gribbs
56
Feb 27, 2003 05:55 AM
shattergsr
Jul 12, 2002 01:42 PM
shattergsr
May 17, 2002 11:44 AM
