zc obd-0 into 92-95 ?? help
probably the obd1 zc driverside engine mount along with the obd1 zc ecu and dizzy which are both very rare, you are talking about a dohc zc correct?
IIRC ZCs respond favorably to boost, but also, again IIRC they have tendency to spin rod bearings, even just stock N/A. If you want to go ZC its probably worth your while to try to find the OBD1 version, its a lot less hassle.
