Hello to all...
Hello to all,
I've been building a drag Civic Type-R EP3 for the past year and a half and still not driven it yet.
Hopefully I can be of some assistance on here and help others out.
Great site too!
Aaron
Great site too!
Aaron
Spec of the car...
Exterior:
Full re-spray from Nighthawk Black, to Championship White C2 Colour code by Pedro E Florindo,
Seibon Carbon fibre bonnet,
Seibon Carbon fibre rear hatch,
Fuel Cut off switch,
GPR Bonnet Pins,
Rear Tinted Windows,
JDM Wind Deflectors,
Mook custom Honda ‘H’ centre cap badges
HIDS4U Xenons – 6000k
15 Inch Team Dynamic Alloys on the front,
Sprayed Type-R 17 inch Alloys on the rear.
Interior:
Fully stripped out interior / approximate weight is around 1050 KG,
Full removal of sound proofing,
Removal of unnessecary wires,
Flocked racing dashboard,
Digital Race Electronics Shift Light,
3 Toggle Switches,
Talex GPS Speed Camera detector,
Custom centre console insert from Carbon Fibre,
On board laptop datalogger,
Two Stroud '5 Point FIA Approved' Harnesses,
Buddyclub P1 Limited Edition Racing seats,
Hauser custom mounts to the roll cage for the Buddyclub seats,
Hauser 8.5 second - FIA & MSA approved roll cage.
Sparco steering wheel,
Sparco Boss,
Sparco buttons for Line Lock
DEFI Gauges control box
DEFI Oil Pressure Gauge,
DEFI Oil Temperature Gauge,
DEFI Exhaust Temperature Gauge,
DEFI Boost Gauge.
Incar and roll cage sprayed Championship White
Suspension and Transmission:
Dogbox.,
Buddyclub short shifter,
Custom Shifter bushings,
Custom Cable bushings,
Energy Suspesnion engine mounts,
HASport Racing Engine Mounts
Clutchmasters Spec FX700 Clutch,
Clutchmasters Spec FX700 Flywheel,
Thedriveshaftshop.com Driveshafts rated to 500 whp,
Quaife ATB LSD differential,
Skunk2 Silver Lower Control Arms
Eibach front camber bolts,
Eibach rear camber arms,
JDM Front Anti Roll Bar and bushes,
JDM Rear Anti Roll Bar and bushes,
Tein Supersteet coilovers with upper adjustable mounts,
Mark Spence custom suspension set up.
Tyres and Brakes:
M&H Racing Slicks on the front,
Yokohama Parada Special 2’s on the back,
Standard discs,
Standard Calipers
Red Folia tec callipers,
Standard pads front and rear,
Line Lock system for drag burnouts
Engine:
Koyo Pro alloy race radiator,
Mitsubishi Evo 8 high pressure rad cap,
Mugen low temp thermostat,
Buddyclub fan switch,
HKS Spark plugs,
Hamp oil filter,
Toda 70 mm throttle body,
RC Injectors 750cc,
Fujita Intake filter,
Standard inlet manifold,
Hondata heat shield race gasket,
BDL Fuel Rail,
Lightweight Red Top Battery,
Turbo Manifold,
Custom 3 inch downpipe,
Turbo,
Heatshield Fireproof rapping,
Earls oil lines,
Racing Intercooler,
Teal Wastegate,
Oil Catch Tank,
BMC Oil breather,
Custom Baffled Sump,
Custom 3 inch turbo back race exhaust
Hondata K-Pro wideband ECU
TDI-North Mapping.
How it first looked...
How it looked a year later...
Another year later...
Exterior:
GPR Bonnet Pins,
Interior:
3 Toggle Switches,
Sparco Boss,
DEFI Boost Gauge.
Dogbox.,
Tyres and Brakes:
Standard discs,
Standard Calipers
Engine:
HKS Spark plugs,
Hamp oil filter,
RC Injectors 750cc,
BDL Fuel Rail,
Turbo Manifold,
Turbo,
Earls oil lines,
Racing Intercooler,
Teal Wastegate,
Oil Catch Tank,
BMC Oil breather,
TDI-North Mapping.
Then will sort out the built engine.
What I want to have happen, is have two maps that I can upload via K-Pro, and have one running 350 hp, and one running 500 hp.
I am running around 350 bhp on stock internals with Q16 Race fuel.
I'm just starting to get all the pieces together, and finalise everything on the car for a start.
Nice, let us know when you get it tuned and what times you put down. What are your goals? If you can drive properly
you should be in sub-11's or high 10's easily.
Good luck
you should be in sub-11's or high 10's easily.Good luck
My goal is to come straight off the trailer and run quicker than 12.5
By the time I'm leaving, I'd like to have accomplished a 11.5
No matter how good a driver someone might be, a 10's isn't possible with my power being at 350 bhp, lol.
However, 500 bhp will certainly crack 10.69 seconds, as my friend Scott Whitelaw proved.
Aaron
Aaron
xtremecivichb
Acura NSX
Apr 12, 2008 01:53 AM
chet
11
Jul 9, 2003 06:44 PM
