Brakes Problem
Old May 17, 2009 | 10:08 AM
Khmi's Avatar
Icon2 Brakes Problem
I am having trouble figuring out, the braking problem on my 91Si Hatch. When braking normally the brakes feel fine, the harder i want to press the brakes the more stiff the pedal feels, but the car does not slow down at a greater rate. It just hit a point where the brakes just don't grab any harder.
The booster is fine, i pumped the pedals with car off and, the pedal sank when i turned the car on. Swapped the check valve with a friends and and it felt the same. MC is good too no sinking.
I had a friend come take a look at the car, he saw that i was running a 15/16 master cylinder. He said that could have been the problem, because i am using a stock booster and prop valve.
Could that be the problem? Should i change the booster only or prop valve only? change both? or just go back to a stock size MC?
Old May 17, 2009 | 10:42 AM
efjones9's Avatar
Default Re: Brakes Problem
did you do the rear disc conversion??
Old May 17, 2009 | 11:32 AM
Khmi's Avatar
nope, drums in the rear
Old May 17, 2009 | 11:44 AM
91DBSexyTime's Avatar
air in the line? but even then that doesnt make sense because you would have to pump them correct? maybe the shoes in the back are just toasted on the brake? mine brake fine but my e brake part of the shoe is bad. thats crazy man.I hate brakes, those are like the one thing I dont like to do, I will mess with wiring and engine stuff but not brakes lol.
Old May 17, 2009 | 01:19 PM
Khmi's Avatar
yeah i thought the brakes were the problem too but i changed all shoes and pads (OEM), resurfaced all rotors and drums. Full bleed after i was done. Same problems
Old May 17, 2009 | 01:22 PM
sh!ft's Avatar
Who the fack changed my title?!
convert to disk and an integra setup
Old May 17, 2009 | 03:40 PM
Khmi's Avatar
Thanks for the advice...anyone else got ideas?
Old May 17, 2009 | 03:47 PM
mahout's Avatar
I vote for something hanging up the pistons in the calipers or the proportioning valve failing if your rear shoes are wearing out fast. Or the pads could just be glazed over and have little frictuion no matter how hard you press the brake pedal.
Since the solution is dirt cheap for fairly good brake pads, try R&R the pads first. Wouldn't hurt to replace them wuith Hawk HPS's because they are a step up anyway. While you're doing it check the pistons push back smoothly into caliper.
Old May 17, 2009 | 10:17 PM
Khmi's Avatar
Replaced pads and shoes with OEM parts, and resurfaced all rotor and drums on Friday. Pistons goes in smooth.
Old May 18, 2009 | 07:27 AM
efjones9's Avatar
no leaks anywhere?? do u have the right prop valve and master cylinder??
airforce21
Suspension & Brakes
Jul 17, 2011 02:48 PM
DoubleDirtyC
12
Jul 11, 2010 03:54 PM
jasonweaver88
Jun 29, 2007 10:31 AM
_BEN_
Jul 4, 2004 10:51 AM
evilblueflames
Jan 31, 2003 08:04 PM
