ob2 communication problem
i went to test smog my car and they ob2 wont read. so i failed. i also used my scanner and it wont read. does any one know why the ob2 plug wont communicate with the scanner?
are you running a different ECU? obd1 perhaps? the wire that communicates between the DLC and the ECU is called the "k-line" and is a blue wire with a white tracer, if you answered my first question with "No" then i'd start there.
no im sure its a ob2. my brother smoged his car with the same motor then we swapped it in mine. his passed cause his ob2 read. all my fuse are there.
did you check both underhood and underdash fuse boxes?
obd2 connector gets its power from one of those fuses.
if this gets bumped tomorrow i will look at a diagram to see where your port gets its power from while i am at work
96-00 Civic's: Fuse 43 (under-hood fuse box, 7.5A) is what powers the DLC.
Also note that "OBD2" JDM ECUs do not communicate with USDM OBD2 scanners...since it's not really OBD2. You didn't list what you're using, so I figured to throw that out there.
But like civic driver said...the motor might have passed smog but are you using his ECU too?
yes im using the same motor harness and ecu, and its not a jdm ecu cause its a cx motor. this was my stock motor so we are just using it to smog.after the smog im goin to put in my b serious. could there be a electrical shortage?
There could be an electrical open too. My meter leads don't work so well through a PC monitor...so you're gonna have to use yours to figure that one out. Either way, there aren't but like 4 wires (maybe 5) that go to the DLC.
Pin 8: Red/Wht - Battery voltage
Pin 12 & 13: Blk - Ground (goes to G401)
Pin 15: Blu/Yel...which then plugs into C131...and out of that connector (pin 21) comes a Lt Blu wire that goes to C8 of the ECU.
This wiring info is for the 96-98 Civic's. The only difference between them and the 99-00 is Pin 15 of the DLC (still Blu/Yel) goes straight to the ECU (A21)...no intermediate connector.
Shaguar47
Oct 1, 2012 08:22 AM
JDMs1eeper
Jul 6, 2003 06:15 PM
TORQUE MONSTER
Apr 21, 2003 01:41 PM
ZColeon
Mar 19, 2002 05:43 AM
chuckd05
Nov 5, 2001 07:33 AM
