Will 13 inch rims fit on a 96 ek civic EX coupe
Old May 16, 2009 | 03:04 PM
theslugbug's Avatar
Default Will 13 inch rims fit on a 96 ek civic EX coupe
need to know ASAP
Old May 16, 2009 | 03:14 PM
IP RACING's Avatar
Default Re: Will 13 inch rims fit on a 96 ek civic EX coupe
highly doubt it. but depends on the rim itself. id say 99% wont fit
Old May 16, 2009 | 03:19 PM
thi3v3z's Avatar
They should as long as they are 4x100mm. But why wud u want 13s?
Old May 16, 2009 | 03:22 PM
theslugbug's Avatar
found a good lookin set of wheel, thats y. are u guys 100% sure it will fit?
Old May 16, 2009 | 03:26 PM
thi3v3z's Avatar
make sure the rims you buy are 4x100 and they will fit
Old May 16, 2009 | 03:29 PM
theslugbug's Avatar
are u sure. i know its 4x100. i just thought the stock civic EX wheel base was made to fit only 14s and up.
Old May 16, 2009 | 03:36 PM
thi3v3z's Avatar
The wheel base on all bases is the same. Sedan, Coupe, and Hatch. All are 103.2"
Old May 16, 2009 | 03:46 PM
theslugbug's Avatar
how come HONDA VX rims didnt fit on my awhile back? did i just need spacers?
Old May 16, 2009 | 04:06 PM
thi3v3z's Avatar
Measure the center diameter of the wheel hub, and the rim to make sure the rim will clear. that might of been your problem. Personally i wouldnt go smaller than 14s on your ex. The ex has a slighty higher weight and the weight ratings on a 13 are lower. Im sure if they make the rim in a 13 they also make it in larger sizes.
Old May 16, 2009 | 06:10 PM
en00be's Avatar
do it...and post up pics...
should look illis
Old May 16, 2009 | 06:13 PM
FearTheH's Avatar
dont get 13s. im pretty sure hes asking if they will fit as in clear the rotors/drums..im not thinking they will. Just like 14" HX wheels wont fit on my 99 00 Si because of clearance issues with the brakes. Go with 14-16s
Old May 16, 2009 | 06:28 PM
94EG8's Avatar
Seagull Management
The rear fit, the front don't clear the front brakes.
theslugbug
May 16, 2009 06:33 PM
HazardizEJ1
Sep 22, 2007 03:55 PM
95BlkGSR
Aug 8, 2005 02:31 PM
Burrito
Aug 6, 2003 01:04 PM
hondalawnmower
Nov 22, 2001 04:42 AM
