Air Conditioning
Old May 16, 2009 | 02:38 PM
m47131's Avatar
Default Air Conditioning
My AC is blowing warm air and I dont know why. I just had a new radiator installed last week. Could that have anything to do with it?
Old May 16, 2009 | 04:51 PM
YeuEmMaiMai's Avatar
Default Re: Air Conditioning
no not unless you damaged an A/C line or forgot to plug in a sensor to the A/C system. What year and make of car?
Old May 16, 2009 | 05:53 PM
m47131's Avatar
99 accord, 2.3L VTEC
Old May 16, 2009 | 08:46 PM
wildstyle554's Avatar
i had this problem. make sure that your heating vents are closing all the way. under the passenger side dash there is an open and close mechanism. dont know how else to describe it but maybe someone has a picture. move your temperature **** and you'll see it rotate. i pushed mine as far in as possible towards the cold side.
there isnt any warm air coming through the vents anymore, but the a/c still doesnt work too great. im guessing that another problem that i dont care to deal with. windows down is more fun
EDIT: just noticed you said it was a 99. could be the same deal. anyone want to confirm?
Old May 16, 2009 | 11:43 PM
it still has the valve
Old May 17, 2009 | 10:09 AM
FunnyVictor86's Avatar
you should start by checking your refrigerant level
Old May 25, 2009 | 03:35 PM
m47131's Avatar
I measured the refrigerant level and the needle moved to the red indicating the freon level was too high. I have never filled the car with freon the whole time I have owned it. What does this mean?
Old May 25, 2009 | 03:44 PM
spoonfedcrx's Avatar
It means you should have a professional look at it.
Old May 25, 2009 | 09:52 PM
notAdiesel's Avatar
i was about to post something like this too.. mine isn't all that cold and i was going to check the level and probably recharge it but does your guys a/c or heat turn off all the way? even when the switch is turned to OFF air still comes out, and if i turn the **** to hot or cold it changes the temp
Old May 25, 2009 | 09:54 PM
notAdiesel's Avatar
don't mean to threadjack but wildstyle is that accessible without removing any of the panels? i just changed the filters so i don't have a problem taking it apart again i just don't remember seeing anything like that that caught my eye
Old May 25, 2009 | 09:58 PM
Jdmman89's Avatar
New User
recharge it and go from there
Old May 26, 2009 | 02:26 PM
pretend thats your car in the picture. right under the dashboard on the left theres a black panel you can remove. it kinda looks like a box. its held on by a plastic screw so you dont need any tools.
Old May 26, 2009 | 07:01 PM
notAdiesel's Avatar
so i just looked at it and couldn't really see anything but i'll take it apart again in the light and look for it
Old May 26, 2009 | 07:36 PM
gqstatus05's Avatar
I have the same issue in my 96 accord. My heat works amazing but the AC blows hot air. I think it has to do with a leak. I remember last summer my buddy put refrigerant in it and as he was doing it I had the AC on full blast.
I felt it getting cold as he was doing it. It lasted like a couple of hours and thats long stretching it. Does anyone have a diagram so I can maybe find the leak?
Old May 27, 2009 | 07:42 PM
notAdiesel's Avatar
try http://www.hondaautomotiveparts.com/ they have nice exploded parts diagrams and you can order whatever you need right from the site if you want to
Old May 27, 2009 | 08:50 PM
Get an A/C die kit, with blulight and glasses. Put dye in and check for leaks. Check all commom areas like condensor, connections where o-rings are such.. Find leak, fix leak recharge and done.
Old May 31, 2009 | 12:11 AM
if you over charge the system you will know it becuase you will hear the compressor cycle on and off rapidly and your car will not get cool. did that by accident of my 94 accord when I recharge it the first time. removed some refrigerant and problem solved. If your pressures are abnormally high and you have never recharged the system, then you got a blockage in there somehwere and you need to find the failed part, replace it, remove blockage if you can or replace blocked part. reseal system with new o-rings and draw vaccum for 4 hours and then recharge with pag oil and r134a to the proper level.
aust 97 coupe
Jan 3, 2009 05:21 AM
pippin65
Honda Civic (2006 - 2015)
17
May 10, 2008 06:33 PM
khmerxnuttyxb
Oct 14, 2007 10:24 AM
markgm
May 9, 2006 05:54 PM
adrenalinejunkie
Oct 2, 2005 06:45 AM
