Engine swap Info, Help
I own the 94 Civic EX and my engine is basically none-repairable,
, SO I'm looking into swaps, money, however, is an issue.
I found the 89-91 Honda ZC DOHC engine for $849 (plus ship&handle) and was wondering if it would fit without any issues, OR is there a cheaper DOHC route to take. Any help is GREATLY appreciated.
My Honda will live on.
, SO I'm looking into swaps, money, however, is an issue.I found the 89-91 Honda ZC DOHC engine for $849 (plus ship&handle) and was wondering if it would fit without any issues, OR is there a cheaper DOHC route to take. Any help is GREATLY appreciated.
And another question, I have a D15B7 laying around and can rebuild it for 400, that includes Full Overhaul Gasket set, Pistons and Piston Rings, Freeze Plug Set, Main Bearings, Rod Bearings, Thrust Washers, Timing Belt, and Oil Pump.
If there are and DOHC engines I can find online or if anyone knows where I can get a DOHC Engine online for around 400 then I will go with the DOHC if not then I guess I'll rebuild the D15
shane7213
21
May 12, 2009 07:58 PM
