4x114.3 conversion
Old May 16, 2009 | 09:36 AM
dakidd05_99's Avatar
Default 4x114.3 conversion
Which setup can be used on a EK. I know the 96 ITR, but can I use the Honda accord?
Old May 16, 2009 | 01:25 PM
Default Re: 4x114.3 conversion
bump
Old May 16, 2009 | 01:49 PM
fastrxu's Avatar
why would you convert from a 4 lug setup to a 4 lug setup
Old Jun 11, 2009 | 09:33 PM
Chrisfrom1986's Avatar
Dont ask a stupid question. If you dont have the answer then move on.
Old Jun 11, 2009 | 10:08 PM
leroyb's Avatar
dam dude relax, is just a q is not like he said some thing bad, but really y 4wide and not 5?
Old Jun 11, 2009 | 10:11 PM
V8 Eater's Avatar
maybe because the guy likes the look of the 4lug itr rims? who knows just give the guy a proper answer, dont answer a question with a question!
Old Jun 11, 2009 | 10:21 PM
CaymanDragR's Avatar
I might not be totally correct, but if the USDM DC2 ITR is the same as the `98 v6 accord, then I would assume you could bolt the accord 4x114 brake setup on the ek.
If you have a choice, I would stay away from the `96 JDM DC2R brakes. I have them on mine and I want to get rid of them. It's basically the same brakes as the GSR, but with a different lug pattern. I have only found one place in the US that sells aftermarket brakes for this useless setup. Everybody has rotors for accords and preludes but not the `96 JDM DC2 ITR spec brakes.
Only reason I have the brakes is because I bought a EK SiR without any brakes on it at all and I needed something to slap on while I'm building the chassis.
Hope I helped.
Old Jun 11, 2009 | 11:24 PM
He is not talking about brakes and no you can not use Prelude/Accord hubs.
The only solution besides 96 ITR hubs is
Honda part number
44610-S10-000
from Honda Ev plus. This only works for the front.
You can use Prelude VTEC discs for 96 ITR because they use the same caliper.
rickkane
Suspension & Brakes
May 23, 2009 11:33 AM
turboeh6
Dec 11, 2007 06:33 PM
X2BOARD
Sep 19, 2006 09:18 AM
JDMGSRB18C1
Aug 1, 2003 04:11 PM
acorn4life
Nov 4, 2002 08:02 AM
