car has to cool down before starting up again?
Old May 15, 2009 | 09:19 PM
Dead CIVIC's Avatar
Veteran: Army
Default car has to cool down before starting up again?
when i drive my car somewere and shut it off. i have to let it cool down before i it will start up again, if not it just turns and turns. this sucks cause it sereausly limits me as to were i can go. i'm tired of going places i can see my car from while paying cause i left it on...someone please help me.
Old May 15, 2009 | 09:24 PM
fungus mungus's Avatar
Default Re: car has to cool down before starting up again?
This happened to my old CRX and a friend of mine's EF Civic. The main relay was the culprit. Just replace it and you'll be fine.
fm
Old May 15, 2009 | 09:25 PM
Dead CIVIC's Avatar
Veteran: Army
i did so recently, that didn't do anything? any more suggestions guys.
Old May 15, 2009 | 09:27 PM
civic_driver's Avatar
Check the coil.
Old May 15, 2009 | 09:31 PM
Former User's Avatar
Is the CEL ON?
When the engine won't start:
1) Listen for whether the fuel pump primes for two seconds when the key is turned to ON(II).
2) Check for spark at the plugs.
Old May 15, 2009 | 09:40 PM
Dead CIVIC's Avatar
Veteran: Army
yeah everything checks out...no cel. good stong prime, coil i've tried others. i was guessing injectors but i replaced them and still. please guys keep it coming.
Old May 15, 2009 | 09:42 PM
batallic's Avatar
did u replace it with a new one or used one
Old May 15, 2009 | 09:43 PM
...coil i've tried others.
Did you actually check for spark at the plugs when the engine wouldn't start?
Old May 15, 2009 | 10:02 PM
trustdestruction's Avatar
This used to happen to my old Civic, and I don't know why this worked, but I changed the fuel filter and the problem went away.
Old May 15, 2009 | 10:05 PM
DownShiftPerformDC2's Avatar
Coolant Temp Sensor, Main Relay, Or Fuel Pump.
Old May 15, 2009 | 10:07 PM
Originally Posted by DownShiftPerformDC2
Coolant Temp Sensor
No offense or anything, but these are different symptoms than the last thread you posted in, yet you said the same thing is the problem.
EDIT: this was before your ninja edit. lol
Old May 18, 2009 | 02:52 PM
Dead CIVIC's Avatar
Veteran: Army
i still cant fugure this out.
Old May 18, 2009 | 10:01 PM
Dead CIVIC's Avatar
Veteran: Army
Old May 18, 2009 | 10:03 PM
Did you try the fuel filter?
It's worth replacing, and when I did, my same exact problem went away. I don't know how it worked, but it did.
It's only $14 or so and your gas mileage may improve depending on how bad the old one is.
Old May 19, 2009 | 05:56 AM
Dead CIVIC's Avatar
Veteran: Army
will do so sir. thanks.
Old Jun 9, 2009 | 05:28 PM
Dead CIVIC's Avatar
Veteran: Army
just wanted to update u guys. i changed the filter. and OMG it worked. thanks.
doefat04
31
May 30, 2011 08:43 PM
knakmuhs
11
Apr 8, 2011 11:09 AM
ge_itr
Jun 1, 2007 03:35 PM
vtecn8ive
21
Nov 5, 2005 09:35 AM
rhl487
Sep 17, 2004 11:53 PM
