oil filter problem
Old Aug 18, 2002 | 12:31 PM
EKB18BPR3's Avatar
Default oil filter problem
as we speak im doing an oil change. my ? is...could i change the filter when the oil ISNT empty? cuz i bought the filter and everything and i also have the tool to screw the filter in/out...but this tool doesnt fit the honda filter.
Old Aug 18, 2002 | 12:36 PM
JaeOne3345's Avatar
Default Re: oil filter problem (dniedacess)
u could be quick about it..it will spill out. i do oil changes all day part time..lol.
buy a filter wrench..looks like pliers...clooses(sp?) and band wrenches are ok too..just make sure they fit.
Old Aug 18, 2002 | 12:38 PM
EKB18BPR3's Avatar
Default Re: oil filter problem (JaeOne3345)
so it will spill if i have oil in there? i got the filter cup looking thing that fits over the end of filter and uses the rachet to unscrew/screw.
Old Aug 18, 2002 | 12:41 PM
kikicamacho's Avatar
GHETTO FIX: stab filter w/ screw driver as close to the back of the filter (away from the block) and turn. Screwdriver = universal filter removal tool.
You will get dirty. This is last resort. Take other car or get ride to auto parts and find the right tool instead.
[Modified by jcamacho, 1:42 PM 8/18/2002]
Old Aug 18, 2002 | 01:48 PM
EKB18BPR3's Avatar
Default Re: oil filter problem (jcamacho)
yeah i gotta get that filter tool. so other than the oil thats left in the filter...nothing will gush out?
Old Aug 18, 2002 | 02:19 PM
Kamin's Avatar
yes its gonna come rushing out if your not fast about it.
Old Aug 18, 2002 | 03:06 PM
kane2g's Avatar
you dont need to change your oil, its way overrated, pay someone to do it, at least they know how!
Old Aug 18, 2002 | 03:10 PM
EKB18BPR3's Avatar
Default Re: oil filter problem (kane2g)
what the **** u saying? that i dont know how? the ******* reason why i couldnt change the filter was cuz i didnt have the ******* special tool bitch. i always change my own oil/filter. maybe if u read u'll know the whole story.
Old Aug 18, 2002 | 03:45 PM
ef ect's Avatar
calm down buddy gust get a rag and grab that thing and trun for all your wouth if that dont work, if you got one get a jar opener/small peice of rubber and that should help you get a grip and those fram grip filters work wonders(no need to look for a sspecial tool next time or the time after that and so on)
Old Aug 18, 2002 | 05:59 PM
97hb's Avatar
I would not use any tool to tighten the filter, just hand tighten. Yeah, oil always gets on my axle, and exhaust manifold . But I can change my oil in like 5 min now
Old Aug 18, 2002 | 08:53 PM
hondafrk's Avatar
Default Re: oil filter problem (97hb)
you wont have any problem changing your filter with the oil level full. Just spin the filter off and make sure that you have a drain pan or something under the filter area. You will only lose the oil thats in your filter and maybe a little more from the block and oil return passages.
You can put oil back into the engine without having the filter on. Oil will not run all over the place... Just pull the filter and change it then add the proper amount of oil back and you'll be fine
Old Aug 18, 2002 | 11:53 PM
DelSol808's Avatar
Default Re: oil filter problem (hondafrk)
since everyone just wants to flame..... if you dont drain it oil will pour out all over you... best to drain before you change... or if you just had an oil change id just hold off until time for the next one to put it on.
Adankid
Jan 1, 2009 03:12 PM
ninety-five_DB
Jul 8, 2006 05:03 PM
EKB18BPR3
Aug 18, 2002 02:43 PM
yellowbuffalo
Mar 16, 2002 05:54 PM
Type Goch
Jul 1, 2001 10:11 AM
