215/45/17 problems anyone? pics?
Old May 15, 2009 | 12:07 PM
RDLIN-IT's Avatar
Default 215/45/17 problems anyone? pics?
I just mounted up a set of 215/45 on my Volk GTN wheels. I havent put them on the car yet. Is anyone else running this same size on their R? I previously ran 205/40 but tires just looked too small..I'm thinking i may have an issue....
Anyone have pics?
Old May 15, 2009 | 12:14 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 215/45/17 problems anyone? pics?
I'd bet you a dollar that they'll rub.
If you want tires bigger than the ones that fit on an Integra, get a car with bigger wheel wells!
Old May 15, 2009 | 12:18 PM
RDLIN-IT's Avatar
I am also running Ground Control/Koni shock setup...I don't like the care slammed on the ground. When you say they will rub do you mean in a straight line or while turning?
Old May 15, 2009 | 12:28 PM
red_crx's Avatar
Those will more than likely rub pretty bad if your slammed. The only tire that fits perfect would be a 215-35-17
Old May 15, 2009 | 12:34 PM
RDLIN-IT's Avatar
Car is not slammed.. I had some fender gap with the previous 205/40 combo. I won't be able to test fit them on car till Sunday so this is going to bug me until i can find out.
Old May 15, 2009 | 12:43 PM
red_crx's Avatar
Sorry, I mis-read your previous post.
Old May 15, 2009 | 01:15 PM
RDLIN-IT's Avatar
NP...rims are 17x7 with 43mm offset..
Old May 15, 2009 | 01:24 PM
jdm_94's Avatar
I'm using 215-40-17 and I have had any problem and looks good.
Old May 15, 2009 | 06:25 PM
migs's Avatar
You should have put 215-40-17's on there. And usually cheaper brand tires are typically smaller.
I had a name brand 215-40-17 and a cheaper tire in the same size. The cheaper tire in the same size was substantially smaller than the name brand.
FWIW. I use 235-40-17 on my car. My fenders are rolled and I have nearly -4.0 camber up front and -2.0 in the back. No rubbage
Old May 16, 2009 | 06:48 PM
RDLIN-IT's Avatar
Yep they rub but only at hard braking in the front. It rubs the plastic fender liner. I could raise it up about 2 turns on the coilover and it might help. The rims are tucked inside of the fender. The rears will tuck also. I'll post up pics tomorrow...
Old May 16, 2009 | 09:52 PM
YellowKahuna's Avatar
215 45 17 never had issues, I don't remember what my settings were cause these were taken a while ago.
Old May 17, 2009 | 03:10 AM
RDLIN-IT's Avatar
Are you sure? those look like 215/40/17. The sidewall looks smaller than the 45 I have.
Old May 17, 2009 | 04:15 AM
Yep, Ive been rolling 17's since 2002 and the reason why I have 45's is, I wanted a bigger side wall to protect my wheels.
Just recently got my 1st set of 16's
Old May 17, 2009 | 05:09 AM
RDLIN-IT's Avatar
Did you modify your front fender liner or remove it? Posting pics in a few..
Old May 17, 2009 | 05:34 AM
RDLIN-IT's Avatar
Old May 17, 2009 | 04:31 PM
nsxtasy's Avatar
H-T Order of Merit
The best size for 17" wheels on an ITR is 205/40-17. It has the exact same outer diameter as the stock size tire, so it won't rub, it will keep the accuracy of your speedometer and odometer, it won't slow your acceleration like bigger tires will, etc.
Old May 17, 2009 | 07:02 PM
Nope everything was there, just rolled the rear fender up some and that was it.
NSXtacy, 40 series tire was too thin for me I bent one rim easily and took them off and went to 45. Car was daily driven and is not tracked at all so 45 was more of what I needed to protect the wheel from Los Angeles pot wholes.
Here is some more pics
Old May 18, 2009 | 04:05 AM
RDLIN-IT's Avatar
Im going to make some more adjustments. Once those are done I'll decide if I'm going to keep them. It really rides well and handles well. I haven't pushed it very hard in a high speed corner section to tell. I still have to lower the rear a couple turns and then check clearance.
BTW I still have my stock wheels for when i start tracking the car. These are just my street tires..
Kahuna look at your sidewall compared to mine...Doesn't yours look shorter?
Old May 18, 2009 | 07:04 AM
look at your rear tire it looks slim. what width is your rim mine was 7.5 in. And I was running Bridgestone S-03, tire companies design tires differently. Go check out the tires and you will see differences on what the sidewall looks like.
Old May 18, 2009 | 04:16 PM
RDLIN-IT's Avatar
here is another pic..
Old May 19, 2009 | 12:44 PM
XANTHODC2R's Avatar
Here's mine stock height on VR GT-Ps 215/45/17. Also wanted the extra "carne" for the LA potholes
Old May 19, 2009 | 03:48 PM
Where were you? missed you at Eibach this year. Someone was selling some cp-r's at eibach you should of been there
Old May 19, 2009 | 04:43 PM
RDLIN-IT's Avatar
I'm going to have to raise the front in order for it to be driveable..Still don't know if I'll keep the tires.. May have to go down to the 215/40.
Old May 21, 2009 | 05:33 AM
nsxtasy's Avatar
H-T Order of Merit
That's a good reason NOT to get 17" wheels. If you want more protection against potholes, you're better off getting 16" (or 15" wheels) with the proper tire size, rather than 17" wheels with oversized tires.
Old May 21, 2009 | 08:36 AM
I did you silly
16x7 +42 RE30's
