What's better str8 pipe or high flow cat?
Old May 15, 2009 | 11:39 AM
Dukie432's Avatar
Icon7 What's better str8 pipe or high flow cat?
I recently bought a new exhaust system online and it didn't come with a cat or anything that connects to my headers. My question is whats better to buy a str8 pipe or a high flow cat converter. What's better performance wise. I live in Texas so there's no smog check or anything to pass
Old May 15, 2009 | 12:09 PM
forcefedferio's Avatar
Default Re: What's better str8 pipe or high flow cat?
Really it depends on the application, i'm going to assume you have a bone stock engine. If i were you i'd leave the cat alone, by putting a straight pipe or high flow cat (resonator) on you may actually see a decrease in low end power, essentially the car will be noticeably slower. If you really desire to have one or the other, i would go with the high flow cat, which is more of a resonator than anything and the car will be less likely to sound like raspy poop.
Old May 15, 2009 | 12:24 PM
Dukie432's Avatar
My bad I guess I should have specified a little better. I swapped a jdm type r motor in my ej2. I also got a whale ***** intake and the 4-1 headers. With that info does your advice change?
Old May 15, 2009 | 12:28 PM
actually, it certainly does haha. I would recommend to you the hytech replica header which can be found on ebay for about $200+shipping nowadays. It's length will eliminate the need for a cat or a straight pipe, and it's design will provide you with ample amounts of power.
Old May 15, 2009 | 12:35 PM
Dukie432's Avatar
I really can't waste to much more money I have put a lot into this motor already. I bought a new stage 3 clutch kit that put me back a pretty penny, then I bought this exhaust system just to realize I didn't have a cat. I looked online for a cat and found both the str8 pipe and a high flow cat for around the same price ($100). But I don't know which to go with. Sorry to give you half the story at a time. I guess I'm trying to boost my post numbers
Old May 15, 2009 | 12:45 PM
98civdx's Avatar
Master Detailer
i would keep the cat in. but then again you cant go wrong with a hytech header.
Old May 15, 2009 | 01:01 PM
Dukie432's Avatar
keeping the cat isn't a option cause I don't have 1 tobegin with
Old May 15, 2009 | 01:44 PM
if $100 isn't a problem, i would just bite the bullet and pony up an extra $100 to get something truly worthwhile, surely you have something that's of no use to you laying around that you could sell!
Old May 15, 2009 | 01:49 PM
Dukie432's Avatar
Money truely is an issue. I dont got 200 but I just need to know which is better performance wise str8 pipe or high flow cat
Old May 15, 2009 | 02:22 PM
batallic's Avatar
straight pipe but u only get like 2 hp, and yur car will sound raspy as hell, and pollute depending on where u live u wont pass emissions
Old May 15, 2009 | 05:11 PM
y2kferari's Avatar
high flow cat FTW!!
Old May 15, 2009 | 07:07 PM
VTECth1s's Avatar
Won't make much of a difference at all but pollution and raspy *** sounding exhaust. But again depends on the motor/engine. As for your typical b-series, d-series vtec or non vtec. You won't feel **** period. Just stick with a high flow cat, as it reduces unburnt chemicals escaping to the atmosphere. And you can save the hassle of more tree hugging bafoons from complaining!
boosted94teggy
Oct 10, 2005 11:01 AM
RadRonny
Jun 9, 2005 09:30 AM
fluke83
Jul 14, 2004 10:49 AM
bob barker
17
Mar 6, 2004 04:12 AM
Audio28
Nov 16, 2002 03:38 PM
