95 Del Sol S D15b7 Boggin, Backfiring. Please Help
Old May 15, 2009 | 01:10 AM
DownShiftPerformDC2's Avatar
Default 95 Del Sol S D15b7 Boggin, Backfiring. Please Help
So I might seem like a newbie on here, But I've frequented some other forums and have been working on owning Honda's/Acura's for the past 6 years. I have a problem that I need help with, BUT I only want help from people who know what there talking about and have experience with the same issue before. So Thank you in advance and please read below.
I recently put a SOHC D15B7 Non vtec in my del sol. Here are the problems.
#1 Its throwing a code but when I jump the service connecter it wont flash the codes for me.
#2 The car idles good, (high but good), Revs fine. Then when I go to drive it as soon as the clutch is out it bogs really bad and backfires. Like it will rev up fine with no problem until you try to drive it. Then it will bog til about 3-4K, Then accelerate fine after that.
Please give me your honest opinions, I've checked the timing it looks great, Plugs look fine, there are no vacuum leaks, and it looks like the PCV was recently changed on the swap.
Old May 15, 2009 | 01:35 AM
trustdestruction's Avatar
Default Re: 95 Del Sol S D15b7 Boggin, Backfiring. Please Help
#1 is being caused by the blown 7.5 AMP backup fuse in your under hood fuse box that I PM'd you about. That's why your clock doesn't remember the time and your radio resets itself. Once you replace the fuse you should be able to pull the code after the next time it comes on.
#2 i'd check the rotor and cap for excessive wear.
Old May 15, 2009 | 03:29 PM
PM'd you back. Thanks. If anyone else has anything to chime in please do.
Old May 15, 2009 | 03:43 PM
I forgot to mention, because I wasn't even thinking about it... before you check the cap/rotor, check the code the ECU is throwing, once you get that backup fuse replaced. It's quite possible and likely that the code is pointing to the source of problem #2.
Old May 15, 2009 | 08:10 PM
Word. Will do . . . BuMp . . . Thanks again.
Old May 15, 2009 | 08:13 PM
egGSR_hi's Avatar
Mine car is also doing the same thing kinda, If I find any good info I post it here.
Old May 15, 2009 | 08:59 PM
Former User's Avatar
The CEL is ON steady but no codes blink when the service connector is jumped, right? If so, there is (1) a short or open in wires running between the service connector and ECU, (2) a short in the wire between the ECU and CEL, or (3) the ECU is bad.
...I've checked the timing it looks great...
Have you checked both the mechanical timing and the ignition timing with a timing gun? Is the valve clearance set to spec?
Old May 15, 2009 | 10:22 PM
Just did a valve adjustment to OEM Specs, Check mechanical and tried changing distributer timing, A buddy has my timing light so havent done that yet. Im going to try a different ecu tommorrow.
Old May 15, 2009 | 11:00 PM
TeamRPM_ZC's Avatar
for some reason, ive been on HT and i noticed everywhere that all our cars have almot the same problem. basicly what your problems your having, i have the same thing, but with mini me vtec.
Old May 16, 2009 | 01:17 AM
I am gunna try a different ECU tommorrow. I replaced my BLOWN back up fuse so I should be able to read my CEL's. I'll post up my findings when im back from the shop. But if anyone has more info or thoughts please voice your opinion.
Yeah its a really annoying problem. Hopefully it'll get worked out tommorrow.
Old May 16, 2009 | 11:29 AM
Bump . . .
Old Jul 13, 2011 | 06:57 AM
Exclusive831's Avatar
Whats up I'm so sure how to use this site! But hope you can help my 93 del sol bogs out and has a check engine light on and some times trows me the battery light as well! Will appreciate if u could help!
DelSloSiwhat?
11
Mar 9, 2013 09:57 AM
FLAASH
12
Jun 3, 2011 04:42 PM
beaver619
Mar 27, 2008 03:18 PM
97grnrs
Jan 2, 2006 11:07 AM
explosive
Apr 30, 2003 11:13 AM
