Effin head gasket moves..??
soo i just did a head gasket on my b16 swap. i used the copper spray this time for a better seal. well i was wipin the stuff off that lil part of the gasket still visible in the corner after the heads put on and noticed the gasket moves a bit. i can also see a bit of oil already leaking from that spot since i covered the cams in oil. if i look closely at the block surface i can see the gasket moving between the head and block. now i had the head checked but not the block. dont tell me the block is effed up...im gonna cry
well i had the block bored over to 82mm and cleaned up. i assumed they checked everything at the machine shop but ever since i had the motor up and running its had head gasket problems, high idle, burning coolant, leaking oil...ughhh
not really a side to side motion, the dowels are there of course ,but more of i can move that lil corner of the head gasket exposed and watch as it moves between the head and block..up and down...
