6-point harness install
yeap, Hard Dog. http://gotspeed.110mb.com/2001_s2000_rollbar.php
here are some pics of the additional brace from the back plate to the roll bar plate, and the spacer welded on.
i thought that there was a harness bar on the hard dog bar, or did you happen to buy one without the harness bar?
btw great install pics. i want a hard dog bar so bad... but i want to try and retain using the stock plastics (modified with removed roll hoops) if its possible
Gotcha: I see the bevel on the nut now. Unusual.
That brace makes it look a lot safer. Does it get in the way of the spare tire on the other side?
the bolt goes through at an angle because the front plate is not parallel to the rear plate. the brace does not interfere with anything but you wont be able to mount the stock roll hoops.
EvasiveMotorsports.com
27
Aug 1, 2006 04:05 PM
b00st-0wnz
Dec 6, 2001 12:19 AM
