Strange VTEC
Old May 14, 2009 | 02:58 PM
VTECROAR96typeR's Avatar
Default Strange VTEC
Alright..about a year ago my ek was in a accident the body was totald but my motor was not.. so i got a diffrent car and the motor kinda acts up, when i turn the car on it idels wierd, the transmission makes a whinning noise when in gear and i releaze the gas pedal, and When i go up to 6k rpm's the vtec dosnt kick in like i use to..
any ideas
Old May 14, 2009 | 03:29 PM
HONDRETTI's Avatar
Default Re: Strange VTEC
doesnt kick in like it used to? so it works? or it doesnt?
Old May 15, 2009 | 04:14 AM
Tiger_Si's Avatar
same problem here, it doesnt kick in as it used to on my B16 and starting to happen in my B18C5....
could it be oil pressure, or oil amount??
Old May 15, 2009 | 04:28 AM
XxBoostfreaKXx's Avatar
any ideas
have you checked your particulate strainer for your vtec solenoid? check it for debris which would impare proper oil pressure and volume from reaching the valvetrain so it can function properly. do not use any petrolium based cleaners on the Oring assy. or it will damage the part
Old May 15, 2009 | 04:29 AM
BoBo Racing's Avatar
might want to check oil, oil pressure or vtec solenoid. and this is the type r forum go ask that question on all motor or hybrids
Old May 15, 2009 | 01:30 PM
jdm_94's Avatar
If the sensor are bad the CEL will go on!!! I don't think that are the sensors. Remove the air filter and drive the car ,in this way you will hear more cleary the vtec. That's will help you to know if the vtec works corectly.
Old May 16, 2009 | 12:50 PM
would a bad fuel pump cause the car to chocke at high rpms.. right now i have a stock d16 fuel pump.. im telling you before the accident the motor was running perfectly
Old May 16, 2009 | 06:59 PM
en00be's Avatar
lol how am i the first one to say this.....Wrong thread
check your oil...my friends civic with a b16 swap did the SAME thing the other day
Old May 17, 2009 | 08:04 AM
yo i askd here because its the same motor that ITR's have, and check what oil ??
Old May 17, 2009 | 08:19 AM
Pr-Type-R's Avatar
your motor oil. ive had the same problem.. then after my oil change it was back to normal.
Old May 17, 2009 | 08:30 AM
you have to check your Vtec oil, just unscrew the vtec solenoid with a pair of vise grips and check the fliud level. it might be really tight so you should prolly use a cheater pipe on the handle. good luck......GFKY!
Old May 17, 2009 | 08:38 AM
Rost's Avatar
No Vtec yo :[
Definitely check your oil, like these guys are saying.
Old May 17, 2009 | 12:18 PM
alright thanks for the info
Old May 17, 2009 | 01:18 PM
CT-26_mk3's Avatar
bad ground??
Old May 17, 2009 | 01:45 PM
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
You might want to try swapping out the oil filter while you get ur oil change and try one from a K series onto your b series vtec block. What this does is increase oil pressure and reduces the bogging out that some people experience with vtec ingagement. A higher oil pressure + sufficient oil level = a well oiled head for more reliable vtec.
Old May 17, 2009 | 01:47 PM
dvs94Teg's Avatar
^ that is if you figure out the problem first, unless this does the job. Just a suggestion, a trick i picked up from a buddy.
Old May 19, 2009 | 09:01 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
wow.....check the sig....
Old May 19, 2009 | 09:19 AM
Fo-Do Fanatic's Avatar
not againnnnn
Old May 19, 2009 | 10:59 AM
lol.....some of you guys crack me up...you have one of the most sought after cars in the Honda/Acura in the U.S......one of the only things you need to regularly do to maintain your motor is change to oil....its what $30-40? if your using good oil maybe $50-60....
vtec NEEDS oil to function....vtec powers the high end of your motor, without it, you may as well be driving a stock LS that is running like ****....lol
CHANGE YOUR OIL!
Old May 19, 2009 | 01:22 PM
CHANGE YOUR OIL!
well MR. Bad *** its not the oil cause i checked it. it was my fuel pump what the car did was choke at the time vtec kicked in. im guessing a stock pump isnt good enough for a type r and it also did the same thing witht the b16 that i had but it choked at low rpms
Old May 19, 2009 | 03:16 PM
lol...damn right...Mr.Bad ***....
im not talking about your particular problem there Chuck Norris....im saying in general, some people neglect to change there oil..... so dont be so quick to judo chop....
Old May 19, 2009 | 09:04 PM
BlueStar's Avatar
i've never heard of a k series oil filter on a b series motor. Are all k series oil filters the same? Does this actually work? sounds interesting..
Old May 20, 2009 | 08:28 AM
dvs94Teg's Avatar
im pretty sure that all k series filters are the same, but first check with the dealers just to be 100% sure. This method does work.
JSpekBB4
Oct 30, 2007 10:23 PM
hoya_10fintec
Feb 13, 2005 08:36 AM
srehmat02
Sep 17, 2004 02:24 AM
speedunlimited
Sep 16, 2004 08:08 AM
NSX Bob
Apr 13, 2002 04:10 PM
