Hasport H22 EG Mounts - Real or Fake?
Hi, I have bought a set of used Hasport H22 EG Engine Mounts which have arrived today.
But looking at them I think there fake, as there is no Hasport name/brand on them.
The only thing on them is T V S 12.9 engraved on the Hex bolts underneath.
Also as seen in picture 2 the rubber insert on the far right mount is damaged, is this any cause for concern?
Anything I should look out for on them or does anyone have any close up pictures of their H22 EG Mounts so I can compare?
Cheers
Cheers
Cheers
Cheers
Pictures added.
Also as you can see in the second picture a bit of the rubber insert is missing, should this be a concern?
Cheers
Cheers
there u go. from the man himself.
as for the rubber.. i wouldnt be concerned.
buying fake mounts from someone claiming them to be real mounts, i would be pissed more than concerned.
if u want comparison pix just for the hell of it.. go to hasport.com
Anyone have an idea if these are Avid Mounts or not.
The mount on the top of my picture has a slightly different shape to the one on Avids website.
However there are a set of Avid H22 EG Civic mounts on ebay at present where this same mounts looks like mine. Link can be found at,
http://cgi.ebay.com/ebaymotors/Avid-...Q5fAccessories
Thanks for the help.
I have the same ones on mine bro.They are Avid racing mounts.They are good mounts.I havent broke any yet but the allen screws do come loose so If I were you,I would remove the screws and put some red locktight on them and reinstall the screws so they dont vibrate loose bro.
