Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 CRV blower wont shut off ????
Old May 14, 2009 | 03:34 AM
m735is's Avatar
Default 2000 CRV blower wont shut off ????
My wifes CRV wont completely turn off the heater/ AC blower. The switch will slow it down, the A/C won't turn on until the switch is turned to about half way on and it will activate the high speed relay (little click heard by blower) when fully turned on. Where should I start diagnosing?
I tried swapping the blower relay under the hood, nothing changed.
Is there a write up somewhere about to remove the dash to get at the switch panel?
TIA
Old May 14, 2009 | 09:13 PM
Splaturn's Avatar
Default Re: 2000 CRV blower wont shut off ????
Try hitting the recirculate button first, then turning it off. It allows the door to fully close. It may or may not help you, but try that first.
Old May 22, 2009 | 02:40 PM
m735is's Avatar
No dice on that one.
Any other ideas?
Old May 23, 2009 | 03:46 PM
92civlude's Avatar
The bower is "always hot" with the ig switch on. The speed is controlled on the ground side of the circuit. There is a blower resistor screwed to the duct right behind the glove box. This may be shorted. disconnect the connector or better yet, remove it from the duct and do a visual on it. An answer may present itself.
Old May 25, 2009 | 02:24 AM
m735is's Avatar
I'll check that out today. The A/C doesn't work either, the compressor isn't engauging. The light on the button works, but no cold air. Hopefully it's all related.
Old May 29, 2009 | 10:11 AM
m735is's Avatar
Default Re: 2000 CRV blower wont shut off ???? Fixed !
The new resistor did it. Thanks, wifes happy again.
Old May 29, 2009 | 01:39 PM
92civlude's Avatar
YEAH!! Ill scratch in another notch on my toolbox!
Old Apr 10, 2011 | 08:01 AM
moebiius's Avatar
resistor or transistor assembly? part number please and thanks a lot for sharing, this really helps!
Old Oct 11, 2018 | 04:59 AM
BigMoi's Avatar
I have a 99 crv the blower wont turn off when truck is on replaced resister even got a oem Honda one and same changed all relays and control cluster to any help is welcomed
86RedFoxBodyGT
Oct 4, 2011 04:36 AM
Hockey27925
Mar 12, 2006 02:16 PM
st1100y2k
Nov 5, 2004 04:26 AM
oMek
Oct 29, 2003 04:16 PM
Finest
Mar 18, 2003 06:04 AM
