Idle Problem
Old May 13, 2009 | 08:31 PM
tyronne1126's Avatar
Default Idle Problem
- Has anyone gotten into this problem?
My idle is barely at 500 most of the time.
When i brake it goes lower.. 300 or less at times
When turning the tire when parked lowers the rpm
The AC drains the car a lot too.
With the AC and trying to reverse and doing a uturn will stall the car..
I do have a system 500 watts + 300 watts
Blue top
1F cap on the 500..
I checked the battery.. Good 14.1V
Alternator ..Good 14.3V
.. I haven't cleaned any of the idle and throttle stuff..
Would it be just cleaning?
Replacement better?
Is it even that?
(Anyone got better pictures of how to clean the idle valve? how to actually take stuff off?
do i need to remove the hoses and what not?
Anything else?
Any ideas will help.. Its getting really annoying.. Its one of the two things i need to fix and i'll be happy..
- Other things are bent control arms on the right front and messed up hub i believe..
(really bad alignment)
P.S. if you are selling some '94-'97 headlights in good condition for retro. let me know.
Old May 13, 2009 | 08:40 PM
nus_dogg's Avatar
Default Re: Idle Problem
My H22 is sorta doing that too. I don't know what it is that would be causing it to do that.
Old May 13, 2009 | 08:41 PM
have you cleaned your idle and throttle parts?
Old May 14, 2009 | 11:06 AM
for those that have cleaned up their IACV, FITV and TB.. how did you remove your screws and what not because i cant get to them.. especially the IACV ones..
Old May 14, 2009 | 11:12 AM
h22 kid's Avatar
show pics where they are located and maybe we can help and get a better understanding... also your idle should be at 700
Old May 14, 2009 | 11:36 AM
okay.. so this is the engine bay of my car..
'94 Accord LX 4Dr
- The black cylinder thing in the middle back is the idle control valve right?
what do i need to take off and clean?
(sorry for the dirty engine bay. a little scared to clean the car..)
.. Top View of what i believe are all those pieces needing cleaning?
Side Views..
Old May 14, 2009 | 11:59 AM
billyrusa's Avatar
Removing the IACV:
Remove the intake air duct to give you more space. I actually also disconnected the MAP plug and TPS plug. I used a 12mm wrench to remove the two bolts. Then disconnected the water hoses and electrical plug. It is a narrow space, but you will be able to reach it after removing somethings on its way.
Old May 14, 2009 | 12:03 PM
h22 kid's Avatar
Originally Posted by billyrusa
Removing the IACV:
yeah i agree remove some parts and it will make it easier... but to remove the iacv its a 10mm wrench..should be two bolts holding it...its not that hard to remove but being that its behind the IM you will have to take your time...but dont be scared to clean your engine bay just take it to those do it yourself carwashes and spray degreaser on it then high power rinse that ****!
Old May 14, 2009 | 12:12 PM
its a 12mm wrench.. the 10 doesn't fit.. the problem is i cant find my 12..
Old May 14, 2009 | 12:49 PM
GhostAccord's Avatar
You could try removing the entire plenum from your intake manifold. That way it will be easier to clean everything.
1. remove air intake tube from throttle body
2. Undo the throttle cable bracket, remove the cable ends from the throttle body.
3. disconnect all electrical connections, ensure to label them before you disconnect them. Don't forget the intake ground on the right end of the plenum.
4. with a 12mm socket and an extension remove the 5 bolts that attach the upper and lower half of the manifold. be careful not to crush or cut the metal gasket. It can be re-used. I've used the same one three times.
5. Disconnect and label all vacuum hoses. Along with the coolant lines that are connected to the FITV and IACV.
6. Carefully lift the complete upper plenum, throttle body, FITV & IACV up out of hte engine bay. I may have forgotten something to disconnect.
7. start removing parts and cleaning with carb/throttle body cleaner and a soft bristle tooth brush.
8. Put it all back together.
If I missed anything please fill in the blanks, I'm just doing this from memory. I used to clean mine on a yearly basis. It was part of my spring preventative maintenance tuneup...
If you can't find your 12mm wrench or socket your going to have a hard time working on any Honda. Using a US standard wrench/socket will possibly lead to stripped bolt heads.
Old May 14, 2009 | 01:03 PM
ill see what i can do.. i bought a 12mm
Old May 14, 2009 | 01:55 PM
so i took off the idle control.. but i cant take off the hoses.. anyone got an idea? i was able to pinch one of the things off but the hose itself is stuck.. how do i take it off?
Old May 14, 2009 | 02:18 PM
Use a set of adjustable/slip joint pliers and grip the hose. Not to tight though, you don't want to crush the inlet/outlet tube. Apply just enough pressure so that when you twist it the hose won't move. If you have the IACV disconnected you can twist the IACV in one direction and the pliers(hose) in the other. You should hear a small snap and the hose should start to turn. Then you should be able to pull it off.
Old May 14, 2009 | 02:53 PM
okay.. NOTHING came out of the hoses.... what should i do about it? i should really bleed my coolant huh? what do i buy? how much?
my little mesh thing was SUPER dirty...
ideas?
Old May 14, 2009 | 04:22 PM
I haven't gotten to drive the car. Waiting for the fan to turn on. The car is still at about 500 tho. I want to do the coolant. But how?
Then maybe check the base idle
If not. Then get the throttle and what not.
Old May 14, 2009 | 04:49 PM
so.... ill just keep updating so you know..
i cleaned the idle valve..
i then adjusted the base idle but how much can i pull out the screw? not sure how much its out.. my brother did it.. its maybe 3-5mm out.. and it sat at barely 500 base idle..
when i drive it now, it at least doesn't drop below 500. it stays at about 800-600 when slowing down and right at the beginning of being at a complete stop .. but slowly drops to 500..
.. should i do the coolant and see how it goes? (DIY on that anyone?)
.. or do you know its probably another part of the car?
.. can i adjust the base idle more?
.. any ideas?
Old May 18, 2009 | 02:00 PM
Okay. So I have a question. After cleaning it, the car runs great when it comes to getting the extra power to keep up with it's needs. (amp, reverse, braking, a/c, car cooling fan).
I want to know what rpm is the car suppose to run at about 70mph? My car runs at 3.5k. My brother has a 97 accord and his runs much less.
Can I adjust the ratios somehow?
Can might be wrong?
The car has been this was before cleaning the idle control valve but not as bad.
Also, the cars shifting isn't very smooth. What can I do?
The car changes gears at about 3000-3500 rpm when doing slightly hard acceleration.
Let me know on any input
Old May 19, 2009 | 09:04 PM
anyone got any input?
P.S. - Still looking for headlights! ASAP!
Old May 20, 2009 | 06:21 AM
Biggs_Drums's Avatar
My car is around 2800 at 70 mph...I think. 95 accord lx same engine.
Kinda headlights you looking for? I have some ebay projectors I don't want them anymore. PM if your interested.
Train
Aug 6, 2007 03:57 PM
BB1_VTEC
Jul 3, 2006 11:20 PM
comteg396
Jul 25, 2005 08:00 PM
Doeboy
Oct 18, 2003 11:26 AM
