emblem holes..
Old May 13, 2009 | 07:25 PM
CPreston's Avatar
Default emblem holes..
how should they be filled, should i just get some of that bondo backing stuff and bondo the wholes, or should i get them welded shut.
Old May 13, 2009 | 07:53 PM
hondaboynky's Avatar
Default Re: emblem holes..
welded!!!!!!
Old May 13, 2009 | 08:25 PM
gorillafart's Avatar
welded... because filling holes with bondo could possibly invite moisture which equals rust... that and filling holes with filler only is a low quality repair
Old May 13, 2009 | 11:55 PM
cashkeith's Avatar
weldeddddd
Old May 14, 2009 | 05:22 AM
CPreston's Avatar
would i have to sand down the rest of the paint on my hatch to the metal then repaint?
Old May 14, 2009 | 02:51 PM
syzurs's Avatar
you can fiberglass the holes. welding causes burnt metal that needs to be rust proof with fiberglass any way. fiberglass won't rust like bondo. no do not sand down the rest of the car to bare metal. this will only waste your time. fiberglass cloth, fiberglass, bondo, etch primer, surfacer, then feather out the paint so that there is no tell line.
Old May 14, 2009 | 04:22 PM
JDM_DudE's Avatar
what i do is, i fiberglass the back of the hole, then i bondo the top.
Old May 14, 2009 | 06:00 PM
CPreston's Avatar
i cant exactly get to the back of the holes though
Old May 14, 2009 | 06:45 PM
JDM_DudE's Avatar
if its a hole smaller than your pinky, im pretty sure the bondo can cover it up if u play with it
Old May 16, 2009 | 08:29 PM
YumYumMilk's Avatar
best bet is to get it welded
Old May 16, 2009 | 08:47 PM
eg_wookie's Avatar
can always use jb weld hehe
Old May 17, 2009 | 03:27 AM
TorganFM.'s Avatar
So if you weld it how do you stop the back side of the hole from rusting?
Old May 17, 2009 | 11:36 AM
gsilnc's Avatar
sand it to metal... dent the area with the holes... then bondo
Old May 17, 2009 | 11:59 AM
Eyger's Avatar
It sounds almost like no one keeps up with the current refinishing market.
There are several options to close an emblem hole properly without having problems in the furture.
You CAN weld the hole shut. This works fine. As everyone is suggesting.
You CAN use a filler to do the job as well. Of course you wouldn't use "bondo" bondo. You would use something more like everglass, which is a kevlar re-enforced filler. Or kitty hair, which is a fiberglass re-enforced filler. You would prep the inside of where the hole is according to the manufacturers specifications, then smear it on from behind and hold it there with a small square of metal until it cures. After that, just sand and prep the front side appropriately.
There is one last option which no one has suggested. And this option is the one that I would do personally. Go out and buy 3m's panel bonding adhesive #3118. It's a two part adhesive which is formulated to be a substitution for welding. It's some serious stuff. Rent the gun from an auto supply place, prep according to 3m's specifications, then squeeze some in there, let it cure, sand and prep. This is what I would do, there are a ton of benefits that I'm not going to get into, that would be another thread altogether.
SixxT9
Jun 21, 2009 12:04 PM
trapper2933
May 12, 2007 08:32 AM
swappedcx
Welding / Fabrication
Mar 28, 2006 01:29 PM
jweezy225
Jul 11, 2004 01:02 PM
deviant1
Jun 30, 2004 04:20 AM
