vibration under acceleration
Old May 13, 2009 | 07:19 PM
1gEF-8's Avatar
Default vibration under acceleration
vibration under acceleration in a 94 eg with b18c1. from off idle to 2750. will the driver side axle without the damper cause this.
Old May 13, 2009 | 07:34 PM
gotz2b16's Avatar
Default Re: vibration under acceleration
usually it's a broken CV.. The inner CV shaft has 3 posts that have bearings on them.. If you beat the hell out of your car, sometimes these posts break off leaving 2 that are un balanced to take the torque.. This creates a vibration..
Bent wheels,
MAYBE a bad torque mount, but highly unlikely..
Is it a low speed vibration (like a wheel?) or a high speed vibration (Like the engine)??
Old May 13, 2009 | 07:39 PM
yayizzil's Avatar
i got the same problem....
bump
Old May 13, 2009 | 07:44 PM
gotz2b16's Avatar
bump
Still didn't add any info.. Can't feed a closed mouth..
Old May 13, 2009 | 08:58 PM
1gEF-8's Avatar
Bent wheels,
new axles. low speed. usually the first three gears. wheels are not bent. vibration can be felt through the steering wheel
Old May 13, 2009 | 09:34 PM
emceefresh's Avatar
could it be an inner tie rod?
Old May 13, 2009 | 10:11 PM
Since 1983's Avatar
Did you buy brand new axles or brand new remanufactured axles? How are your tie rods? Motor mounts? Tire pressure and wheel balance?
Old May 13, 2009 | 11:31 PM
waaBAAH's Avatar
no...there is only ONE "suspension" component that will shake under "accel." weak struts.
as for shaken under accel.. only causes i can think off would be ...
cv axle(s)
slipped belt in tire
weak struts
Old May 14, 2009 | 08:55 PM
1gEF-8's Avatar
new reman. tie rods good no play. tire pressure is 35psi. wheels are balanced(first thing i checked).
Old May 15, 2009 | 01:44 AM
waaBAAH's Avatar
what kind of axles do you have?..from what car make?
Old May 15, 2009 | 10:49 AM
1gEF-8's Avatar
axles are from kragen.
Old May 15, 2009 | 01:32 PM
waaBAAH's Avatar
Old May 16, 2009 | 12:57 PM
1gEF-8's Avatar
what do you mean by car make?
Old May 16, 2009 | 01:47 PM
IhateworkingoncaRs's Avatar
If the problem never accured until you got the new axles then I'm positive it's the axles. Only problem is which side haha. You can rule out tires if the problem is not there during cruise. Vibration under acc or decc is almost always drivetrain related.
Old May 17, 2009 | 02:20 AM
waaBAAH's Avatar
if you had to order these halfshafts again... what would you tell the dude behind the phone?
would you say...ah yes sir...i would like some kragen halfshafts.
or
would you say...ah yes sir..i would like kragen halfshafts for a civic...and not just any civic..lets try the 99 civic dohc vtec model please.
Old May 30, 2009 | 11:12 AM
1gEF-8's Avatar
or
did you read the first post?
Old May 30, 2009 | 11:49 AM
waaBAAH's Avatar
yes i did...do you know what setup your running?
lets see... 94 EG with teg motor.
that leaves two options...either civic axles or integra axles. granted i dont think civic axles will even fit but i do recall one integra axle for passenger side not having an intermediate section. you would want an intermediate section so i was just trying to clarify the EXACT setup and year make and model of what frikken axle you are running...
is this question to hard to ask? What frikken axle setup you running? geez
Old May 31, 2009 | 09:34 PM
1gEF-8's Avatar
1gEF-8's Avatar
everything for a teg. including front knuckles
vtecnique69
Suspension & Brakes
Apr 8, 2014 09:07 PM
vtecnique69
Honda Civic (2006 - 2015)
Mar 19, 2014 04:26 PM
L2ILL
Oct 22, 2012 01:38 PM
C_Rock77
Sep 5, 2008 09:32 PM
corince06
Jul 26, 2008 02:58 PM
