any advice for my gsr??
Old May 13, 2009 | 05:24 PM
4 door beast's Avatar
Icon7 any advice for my gsr??
hey, im going to high school drags to run my GSR for the first time any advice for racing since ive never raced before ! also any tweaks i should make before racing to the engine i wannna get the best time for a pretty much stock gsr 4 door!! please let me know !!!
Old May 13, 2009 | 05:31 PM
B20EF's Avatar
Default Re: any advice for my gsr??
Try not to get nervous and stall it! Personally i just made sure all routine maintenance was up to par - oil, air filter, tranny fluid, spark plugs, maybe drop your tire pressure down a few psi in the front...
It's going to be more about you learning how to drag your car, it just takes practice.
Old May 13, 2009 | 05:49 PM
WDG_729_ITR's Avatar
If you launch it, don't take the RPM's up too high because you'll just spin...shift right before smacking rev limiter...maybe take out your back seats or anything that would be easy to remove to make your car lighter...make sure not to miss any gears lol or grind...always have the clutch pushed in all the way before shifting and make sure you are in the next gear before releasing...and the rest just takes practice...but those are a few pointers based on my experiences.
Old May 13, 2009 | 06:01 PM
pdeniz's Avatar
dont worry about fast times just worry about launching dont pop ur clutch let it out kinda fast without dumping as far as rpm to launch at, try 3500 and work up from there because u dont want to bog and u dont want wheel spin so work it out from there ... oh and dont move ur hand faster then ur foot try to concentrate and u should be good ....
Old May 13, 2009 | 06:40 PM
VTEC_PRODUCTION's Avatar
stop acting like a ricer. advice giving session over
Old May 13, 2009 | 06:47 PM
jhammond_82's Avatar
Reject Papi
"granny shiftin, not double clutchin like ya should" lmao.... dude i stall my **** all the time if i don't concentrate on it. not sure what it is, but its like a pogo stick on the floor. grabs like a mother though! anyway, yeah, don't wanna cause to much tire spin. and don't hold it at WOT too long off the rev limiter, it'll only hurt you.
Old May 13, 2009 | 07:17 PM
okay cool good advice will wieght reduction"removing interior" really make a difference??
Old May 13, 2009 | 07:21 PM
Well...some claim that it does...and every little thing counts if you're trying to get the best possible time right?...don't start ripping the car apart just to reduce the weight by like 20 pounds though
Old May 13, 2009 | 07:24 PM
Schister66's Avatar
Man U FTW
Don't worry too much about showing off at this point since it's your first time. Don't bother removing your seats or bothering with "mods" for the day. Just practice. Your driving style alone is going to dictate your times. With practice, you can start doing the other things to improve your times. For instance, my first few track passes, i ran mid 13's and was happy; however, with the power my setup was making, i should have run in the mid 12's. Through practice (and an additional 150whp now ) i'll steadily improve my times. Good luck
Old May 13, 2009 | 07:31 PM
Originally Posted by schister66
don't worry too much about showing off at this point since it's your first time. Don't bother removing your seats or bothering with "mods" for the day. Just practice. Your driving style alone is going to dictate your times. With practice, you can start doing the other things to improve your times. For instance, my first few track passes, i ran mid 13's and was happy; however, with the power my setup was making, i should have run in the mid 12's. Through practice (and an additional 150whp now :p) i'll steadily improve my times. Good luck
x2
Old May 13, 2009 | 07:58 PM
OrangeTeggy's Avatar
Yeah were having a highschool drag night every weekend now at the local track here, kinda weird how it came up all of a sudden
Old May 13, 2009 | 08:16 PM
senser1080's Avatar
Yeah, I take out everything that moves, or can move inside my car, such as my jack, spare, floor mats, and what not. Sometimes my seats, but I'm so lazy.
Old May 13, 2009 | 10:20 PM
Inaccurate's Avatar
https://honda-tech.com/forums/acura-integra-6/when-should-i-shift-2560037/
VISIT THAT
TEACHES U EVERYTHING U NEED TO KNOW
Old May 14, 2009 | 04:28 AM
nsxtasy's Avatar
H-T Order of Merit
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old May 14, 2009 | 08:12 AM
fsg231's Avatar
drop 10psi from your front tires...add about 5more to the rears... dissconect muffler part of stock exhaust... remover intale pipeing from air box..( only for the drag strip ) install new spark plugs when you get to the track... change fuel fitler...new dissy cap and rotor. Slightly advance dissy as well at the track. Remove passanger seats front and rear... spare tire, jack, trunk cover, any free weight. Make sure you have as little fuel as possible 1/4 tank or less. Launch at 4000 don't floor the throttel rite away...kinda ease into WOT. 93 oct.
magicaltrout
Mar 23, 2006 03:19 PM
iSpeeD_GSR
Oct 8, 2004 10:16 AM
sp00led
Apr 2, 2004 03:01 AM
jessevtec
Nov 19, 2003 09:45 PM
S2KILLA
Mar 31, 2002 02:01 PM
