What do you think of these spark plugs?
Old May 13, 2009 | 08:20 AM
1BADEGDC2's Avatar
Default What do you think of these spark plugs?
my homie picked up a single slammer on the streets, we pulled the plugs out and they kind of smelt like gas ...
Old May 13, 2009 | 09:46 AM
bernabeguzman's Avatar
Default Re: What do you think of these spark plugs?
too much fuel son, all the black is carbon monoxide with is cause from a non clean burn, you need more spark or need to back off the fuel by lowering the pressure with a afp regulator or new chip in ecu
Old May 13, 2009 | 10:07 AM
1BADEGDC2's Avatar
ok but should they be this wet since the motor hasnt been runnin for a month?
Old May 13, 2009 | 10:21 AM
Adankid's Avatar
what are they wet with? gas or with oil?
Old May 13, 2009 | 10:44 AM
1BADEGDC2's Avatar
smells like gas, but i honostly can say for sure ...
1BADEGDC2's Avatar
it doesnt feel thick like oil either
Old May 13, 2009 | 10:48 AM
TravisCadello's Avatar
Ill be the head has bent valves. this is how my plugs looked when 12 valves were bent and didn't wanna start. never know till you put the motor in and try in start it. may just be stock spark plugs from the 90's.
waaBAAH's Avatar
if the car hasnt been running in a month, then i would assume someone was cranking the car for quite sometime.
was it hard to start that first time you tried cranking the car?
did you install anything like battery or jump it to get it started? if so... then how many times did you try cranking it?
i bet your oil smells liek gas a littel bit and is more runnier then oil....check your oil.
basically what i am getting at is someone might have been cranking the car and flooded the motor
Old May 13, 2009 | 10:49 AM
yea, like a bad dizzy and they kept cranking it with no spark.
Old May 13, 2009 | 04:09 PM
1BADEGDC2's Avatar
thats what im thinkin, he bought a single cam to replace his motor(siezed) and we pulled the plugs to replace em and i saw this. The motor hasnt been put in a car or anything yet, its just sittin there waitin ... thought i would ask but ill get back to ya when the motor is in ...
Old May 14, 2009 | 06:17 PM
1BADEGDC2's Avatar
ok so i pulled the intake manifold off to replace it, and a lot of fuel fell out, what would be the best way to empty it out? also we pulled the headers off and cylinder 4 seemed a bit oily, maybe bad rings?
Old May 14, 2009 | 06:46 PM
roadsqueegy95's Avatar
ya id say tear down and pull pistons and replace rings
Old May 14, 2009 | 08:18 PM
civic_driver's Avatar
Looks like the motor is running rich. Also, those electrodes on the spark plug don't look too good. You have to replace them anyway but you might be having other problems with this motor besides spark plugs.
Old May 14, 2009 | 08:24 PM
dam, fuel fell out the intake mani. daaam bro! Good Luck!
Old May 15, 2009 | 11:39 PM
1BADEGDC2's Avatar
would a compression check help me any?
Old May 15, 2009 | 11:45 PM
b18cKoupe's Avatar
maybe you should figure out why fuel fell out of the intake manifold. Is an injector stuck open? is the regulator bad?
Old May 16, 2009 | 12:41 AM
waaBAAH's Avatar
more then likely the motor was flooded pretty bad. long time cranking it would result in fuel in the manifold. if the vehicle was to start up, the fuel inside the manifold wouldnt be a problem anymore.
new plugs..oil change, then start a diag. of why the car doesnt start.
Old May 16, 2009 | 02:54 AM
1BADEGDC2's Avatar
well motor is outside of car so how would i go about doin this?
this is what i wazs thinkin, the dumfuk cranked the car and flooded it with gas, but i think if i go ahead and replace everything it should be ok, now if i do a compression check what would some respectably numbers be? i know the motors not warm, and do the headers need to be on or just im? at wot right ...
Old Jun 13, 2009 | 04:16 AM
1BADEGDC2's Avatar
well the motor started up fine and everything, no problems, i still have to do comp. check so ill get back to yall ...
Old Jun 13, 2009 | 08:01 AM
ddd4114's Avatar
Old Jun 13, 2009 | 11:22 PM
waaBAAH's Avatar
if the car isnt sputtering or anything..comp check really isnt required.
how does she run?
Old Jun 14, 2009 | 04:27 AM
1BADEGDC2's Avatar
well shes running good and strong, it has a small tick to it, thinkin it might need valve adjustment first ... but i still wanna do comp check just cause, and leak down... no sputterin, it was smokin white a lil at first but the exhaust was full of oil from the last swap(blown motor)
tianporn
Oct 30, 2014 06:21 PM
afnan
Jan 17, 2014 06:08 AM
hawjboi
17
Nov 11, 2008 08:56 AM
terribl3jon
Aug 21, 2004 01:19 PM
neumonik
Mar 13, 2002 04:15 PM
