Suspension & Brakes Theory, alignment, spring rates....
sway bar question
Old May 13, 2009 | 08:10 AM
wow_ohoh's Avatar
Default sway bar question
hi guys, i heard that sway bar will make a big improvement when turning the car, so anybody knows what brand is good? every opinion is appreciated. thanks
Old May 13, 2009 | 09:22 AM
amej8's Avatar
Default Re: sway bar question
Smaller OEM ones:
- 13mm 99-00 Civic Si
- 14mm Integra GSR
I had the 13mm myself and noticed a difference in handling. It wasn't anything extreme but still noticed better handling.
Bigger OEM:
- 22mm CTR
- 23mm ITR (this is what I have now, well it's in the mail and it's not on my car yet)
There are also loads of aftermarket support. ASR (They even make a 30+mm), Blox, Cusco, etc. IMHO, it depends what you want / your goals for your car.
Also remember if you go for anything bigger than the 13/14 ones, you'll need a subframe reinforcement brace to strengthen the weak civic stock subframe. You can go with ASR or Beaks (go with ASR IMHO, but people also swear by Beaks).
And if you aren't already lowered or have performance springs / shocks, or coilovers, I would get those first.
Old May 13, 2009 | 09:41 AM
jeffsciv23's Avatar
are sway bars interchangable? i have a set of LCA's and sway bar off of a ef si that i was gonna use for my wagon awhile back. dont have the wagon anymore but have an eg coupe now, are the LCA's and sway bar compatible?
Old May 13, 2009 | 06:32 PM
JNocon's Avatar
There are some part(s) interchangeable w/ EG and EF, but not all. I remember back in the days, we were swapping the front strut bar and rear lower bar from an EG to my friend's EF and they both fit. So, I don't know about the anti-sway bars, if I were you, I'll give it a test fit. If you got some $$$$ to burn, maybe buy some aftermarket ones that would fit perfect on your car. Here's my EG when I removed the oem GS-R sway bar to the aftermarket ones.
Old May 14, 2009 | 10:21 PM
big boy's Avatar
I don't know too much about suspension but I just put a blox sway bar on my dc2 and yea I felt a difference stiffness wise with the blox sway bar compare to the stock gsr sway bar
Old May 17, 2009 | 10:21 PM
Joel.'s Avatar
I C U P
Going from no rear sway bar to an ASR 24mm sway bar with the ASR brace, I felt a HUGE difference in taking corners. ASR all the way!
Old May 18, 2009 | 08:31 AM
mugen si's Avatar
i just installed the asr subframe brace on my em1 and left the swaybar off untill my new bushings come in...and i notice that the rear is just as stiff, if not stiffer with the rear brace w/out the swaybar.
Old May 18, 2009 | 09:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What do you mean by "stiff"? An ASR brace by itself, which acts basically as a tie bar, does nothing whatsoever to affect ride quality or change suspension stiffness. Even a sway bar does nothing to affect ride quality, except when cornering or when driving over uneven roads.
Old May 18, 2009 | 12:53 PM
mugen si's Avatar
what i meant was the rear seems almost the same right now as it did with the swaybar in the corners. it has the same firm, planted feel. some understeer of course but not as much as there should be.
mike_teg
Suspension & Brakes
Sep 27, 2012 04:34 PM
clean_sol93
Suspension & Brakes
23
Dec 5, 2011 03:44 PM
remoer
Suspension & Brakes
May 20, 2008 04:45 PM
rehab_this
Suspension & Brakes
Feb 20, 2007 11:10 PM
crazy_ham
Apr 6, 2003 08:59 AM
