USDM midpipe and JDM midpipe
Old May 13, 2009 | 07:20 AM
jdm_94's Avatar
Default USDM midpipe and JDM midpipe
Hi,
Any body know if are the midpipe from USDM Type R and JDM Type R the same??? I just need if they have the same long. I have a 4to1 JDM header with JDM cat but I don't know if the midpipes are the same or will be need some modification. Any help will be apreciate.
Old May 13, 2009 | 10:38 AM
BlueIntegraBoy's Avatar
Default Re: USDM midpipe and JDM midpipe
JDM b-pipe is slightly longer than a USDM b-pipe.
Old May 13, 2009 | 12:26 PM
jdm_94's Avatar
That's mean that won't put my header+JDM cat converter with my USDM midpipe without another modification!?!? Do you know how slightly longer it is???
Old May 13, 2009 | 12:31 PM
Maybe like 6".
Old May 13, 2009 | 05:22 PM
donut.'s Avatar
usdm cat is 18" and jdm is 12" iirc
Old May 13, 2009 | 07:57 PM
RockinaRHard's Avatar
IIRC...
jdm 4-1 header- jdm cat- jdm catback.
jdm 4-1 header- stock length test pipe- stock cat back.
srry if this dont help.
Old May 14, 2009 | 03:06 AM
Stinkycheezmonky's Avatar
Suspetise...
That should bolt up to the stock US midpipe. I had a Toda header (JDM "size"/length) and OEM JDM cat, and it bolted up to my stock midpipe ok.
Edit: If you have the parts already, why not just try it? If it doesn't work, you'll know right away.
Old May 14, 2009 | 11:39 AM
jdm_94's Avatar
Already have the header, just asking because a friend of mine selling me his JDM cat converter and I just want to be sure first than spend the money.
Old May 14, 2009 | 11:57 AM
try, fit, buy if local...
Old May 14, 2009 | 12:00 PM
Suspetise...
I'm pretty sure it'll bolt up fine. Can anyone else confirm?
Old May 14, 2009 | 11:18 PM
donut.'s Avatar
no it won't. like i said, the jdm cat is 12", usdm is 18"..............thus, your piping is going to be 6 inches short. just use your stock cat and have it modified to bolt up to the header since the collector is 2.5"
Old May 15, 2009 | 01:41 AM
Suspetise...
Ugh, I think it's been too long since I had all that **** in my hands. In thinking this through more and remembering other ****, I did need to use a test pipe because the cat wouldn't work.
Old May 15, 2009 | 09:14 PM
EF9Fanatic's Avatar
I can confirm that the JDM midpipe is approximately 6" longer than that of its USDM cousin. My setup goes 96 spec JDM header -> Custome lengthened test pipe (Lengthened 6") -> T1R 63s catback.
I also notice that because of the length differences the hanger bracket for the midpipe is in a different place so mine had to be cut off and rewelded.
Old May 15, 2009 | 09:22 PM
My exhaust setup is a 98 spec 4-1 manifold + T1R JDM Length Racing Converter + Buddy Club Spec II (I believe all BC exhausts are JDM length). Everything bolted up fine and is of correct length.
Justimo
Mar 23, 2010 06:20 PM
ednyboo
Apr 26, 2007 05:10 AM
austrian type-R
Feb 16, 2004 02:39 PM
2k1TypeR0610
Sep 28, 2001 08:16 AM
