trouble starting after LS swap into 91 SI
Old May 13, 2009 | 05:28 AM
laoboisosilly's Avatar
Default trouble starting after LS swap into 91 SI
i used all the original harness and im using a PG7 ecu. turn the key, fuel pump works and it does get spark.
in fact it starts... just shuts right off immediately, i took off the fuel rail, held the injectors and tried to start and the injectors only spray ONCE. if i turn the car off completely and try again it will spray again only ONCE.
what could be causing my injectors to only spray once? ive checked all the grounds that i can think of ( VC, tranny, thermostat ) and nothing.
Old May 13, 2009 | 05:43 AM
crxblues's Avatar
Default Re: trouble starting after LS swap into 91 SI
maybe timing is off?
Old May 13, 2009 | 05:45 AM
redflaredcrx90's Avatar
change the ecu
Old May 13, 2009 | 06:27 AM
Originally Posted by redflaredcrx90
change the ecu
could that possibly be the problem?
Old May 13, 2009 | 11:10 AM
4g4d's Avatar
New User
Ya it's probably the ecu. I would use the PR4 ecu.
Old May 13, 2009 | 11:19 AM
northemt88's Avatar
it should still start but just wont run the same as the pr4,Only one injector is firing?
Old May 13, 2009 | 01:11 PM
kp's Avatar
kp
All four fire, but only once.
Old May 13, 2009 | 04:46 PM
chwkef's Avatar
swap a pr4 in there man
Old May 14, 2009 | 11:37 AM
northemt88's Avatar
might be your injectors,no code 43,or injector code?
Old May 14, 2009 | 02:15 PM
hfrex's Avatar
try the injectors! my friend went through the same and he did many things to it but never changed the injectors...... when we change the injectors it started right away!! also check all your grounds!! specially the one on the termo housin!!!!
Old Jul 2, 2009 | 07:51 PM
up!! still need help. i dont have much time to ponder around and look to find the problem.. just need things to go straight for lol
no codes, checked all grounds, redid dizzy wiring. only thing i havent done is try a new set of injectors.... but could it really be injectors? even though it sprays once
Old Jul 4, 2009 | 10:33 PM
89sihatchls's Avatar
injectors might be the problem i had same problem cuz i bought obd2 injectors when i needed obd0 injectors because of the resister box try the injectors the right ones
Old Jul 12, 2009 | 10:26 AM
changed injectors same issue.... eh wtf is wrong with this thing
Old Jul 13, 2009 | 06:32 PM
today i changed injectors to another set. changed the ecu to a pr4. replaced the main relay, DOUBLE checked all the grounds, and redid the OBDo to OBD1 dizzy plug conversion and still the same problem...
when it starts for its few seconds its sounds ALOT better than before, but it still shuts off after starting...
Old Jul 14, 2009 | 06:01 AM
jlicrx's Avatar
are you running OBD0? what distributor is on it? OBD0 ECU requires the use of OBD0 distributor - OBD1 distributor will not work
harley78
Dec 22, 2014 03:12 AM
jvw1981
Jun 21, 2013 12:44 AM
SpoonCivicSir20
12
Sep 19, 2009 07:26 AM
posjr
Nov 22, 2006 04:40 PM
