Difference in b16/gsr cam rail bolts??
Old May 13, 2009 | 12:58 AM
hatchet_honda's Avatar
Default Difference in b16/gsr cam rail bolts??
im assembling a 95 gsr head on my b16a swap and im running into problems. i was missing a few of the cam holder bolts so i ordered them from honda. theyre the large ones in the middle part of the rails. well the old ones tighten and torque down fine but the 5 new ones dont snug up at all and im def not gonna crank on em and risk snapping one. is there a difference between b18c and b16a cam bolts? they thread in fine and look the same but dont tighten up. part numbers are the same but these things def arent the right ones...what am i missing here?
Old May 13, 2009 | 05:40 AM
dephtone's Avatar
Default Re: Difference in b16/gsr cam rail bolts??
I just swapped GSR cams into my b16 and I used all my b16 bolts for the cam holders, everything snugged up just fine, they hold my cams down and everything. Maybe they gave you the wrong ones?
Old May 13, 2009 | 10:35 AM
you just swapped cams. the head is still b16. i have an entire gsr head. and since theres no close acura dealer here in indiana i had to go to honda for the bolts. the original bolts work fine just these new ones dont which makes me think theyre diff. theres only 2 diff bolts i could get and its obviously not the 10 mm ones
Old May 13, 2009 | 10:40 AM
dephtone's Avatar
Ohh my bad, I read that wrong, I read you swapped out the cams not the head my fault... Bump for answers for this guy!
Reading owns me
Old May 13, 2009 | 11:09 AM
im overlooking something cause both acura and honda part numbers are same and the bolt size is too.. 8x50 so its like wtf!
Old May 13, 2009 | 10:06 PM
old one on left new honda bolt on right... they look identical but the new one wont tighten down!
Keenor
Jan 24, 2011 12:48 PM
jspeceg
Jan 29, 2009 07:37 AM
1rude2l
Jan 18, 2009 07:56 PM
poorman's type-r
Jun 13, 2006 01:32 PM
spoon23_JDizM AkA SpOoN20
Jan 13, 2005 06:15 AM
