over heating trouble. need help please
my prelude is turbo and have over heating problem. i've changed the thermostat, vented hood, extra fan, and high pressure radiator cap. Can anyone help. thks much
Like Kronn said, check your coolant level often, this past weekend me and my brother were able to find the root of his overheating problem, a small leak that came from a small hose that connects to the iacv, it was way deep in there and had to disconnect like three other hoses to make room. I'm not saying this is your problem but might be something like this. Also check your radiator specially if it's the stock one and do a flush, see if that helps.
have you had this problem since you went turbo? definitely do a cooling system flush to get the old crap out if you haven't already. some people have had good results using redline's water wetter. it's possible the water pump is going if there hasn't been regular cooling system flushes; there were pics floating around here a little while back where the guy's water pump literally had no fins left on it to churn the coolant.
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
