Brake booster, FPR and other parts
Old May 12, 2009 | 10:36 PM
civic_driver's Avatar
Default Brake booster, FPR and other parts
Hey guys,
I was wondering, since vacuum is required for the proper working of the brake booster and FPR, how does it work under boost (in which case there's no vacuum)?
For example I understand that you never brake and gas at the same time (for street driving) but what about the FPR? How does it work under boost when it requires vacuum for the proper working?
Thanks a ton!
Old May 12, 2009 | 10:43 PM
Garage 808 Hatch's Avatar
Default Re: Brake booster, FPR and other parts
the brake booster has a check valve, so no worry. the FPR raises the fuel pressure 1psi for every 1 psi of boost to keep flow the same against the added air pressure in the runners.
Old May 12, 2009 | 10:46 PM
ghjh's Avatar
Banned
http://www.trade9shoes.com
Old May 15, 2009 | 10:00 AM
So does the stock FPR on a civic work with boost or only with vacuum?
Old May 15, 2009 | 10:20 AM
kyden's Avatar
Thanks a ton!
i wouldn't say never. brake boosting!
but the fpr does work under boost.
Old May 15, 2009 | 10:30 AM
b20beast83's Avatar
i never got brake boosting to work on the highway
how do you guys do it?
Old May 16, 2009 | 04:31 PM
kte324's Avatar
Basically your holding the brake to put the engine under a load while maintaining a certain speed and, most important, building boost. Once you got the pressure you want then let go of the brake and feel the power or wheel spin. Thats the way I look at it.
Old May 16, 2009 | 08:46 PM
b20beast83's Avatar
i have hold the brakes on the hway and throttle and t wont build any boost
1SlowSi
Suspension & Brakes
Dec 27, 2008 11:14 AM
crawlin
Nov 19, 2007 09:22 AM
SpeedoKing
Oct 24, 2007 11:25 AM
SleepingSmurf
Aug 31, 2004 02:38 AM
