Helpp! Car shaking!!
Old May 12, 2009 | 07:00 PM
scspeed's Avatar
Default Helpp! Car shaking!!
So i have a built boosted gsr making 389whp at 319ft lbs of torque. Its been running great, i just took a trip out to PA which was lik a 6 hour drive there and back for me. The car ran great except when i was driving on the way back i noticed that if i got heavily into boost, or almost at full boost the car started to shake pretty damn bad. Almost felt like i had an axle going or like all four of my wheels were unbalanced it was so bad...
I dont know what the problem is. Like i said its only when i put a large load on the motor...close to full- or full boost. I have stock mounts however they are filled with inserts, they have been fine for a year now but im thinking maby on just finally broke??
I checked all my axles were good, lugs where tight, wheels were balanced i dont know what els it could be. Its got to be my mounts.
My motor runs find with no knocking or ticking, bearing clearances are good and i have great oil pressure. So i know its not my thrust bearings fro my crank or anything like that...
PLEASE HELP!@ ( Again this ONLY happens/shakes while the car is being put under a large load)
Old May 12, 2009 | 07:15 PM
slick91's Avatar
Default Re: Helpp! Car shaking!!
what happens when the car stands in one place?
Old May 13, 2009 | 04:10 AM
tannerhoops's Avatar
Old May 13, 2009 | 04:12 AM
I don't know if this helps but one time I got new rims and tires and the guy I took it too to balance them forgot to put back in the wheel spacers. When I was on the freeway my car started shaking violently. I pulled over and called him to bring them to me when I realized they weren't on there and everything was fine after that. Almost anything can cause vibration though G/L
Old May 13, 2009 | 04:59 AM
scspeed's Avatar
I can stage the motor sitting still puting a load on it building boost and the car will not shake. its only when i put a heavy load on it while driving nomatter what the speed.
Old May 14, 2009 | 06:36 AM
scspeed's Avatar
Anybody ever have this problem??
Old May 15, 2009 | 08:39 AM
scspeed's Avatar
Bump, Broken motor mount?? Controll arm bushing?? What do you guys think? Thats about THE ONLY two things i hanvt checked yet.
Old May 15, 2009 | 09:12 AM
leonb2004's Avatar
Sounds like a motor mount to me. Def check them out, Hasport mounts are a win in my book.
Old May 15, 2009 | 02:30 PM
scspeed's Avatar
What is the easyest way of checking adn identifying a bad mount? rev the motor and watch it to see where it tourqes? Or do i have to take each one of and inspect? cuz that would suck...I looked the mounts over quickly when i had the car on a lift and i didnt really see anyhting that cought my eye...idk.
Old May 21, 2009 | 07:16 AM
scspeed's Avatar
Bump im leaning more towards my differential now...I think that is the issue. Anybody ever have this problem?
Old May 27, 2009 | 01:25 PM
scspeed's Avatar
ttt
Old Jun 3, 2009 | 01:18 AM
Fastasscar's Avatar
motor mount and the torque mount! they all collapse! change them.
Old Jun 3, 2009 | 06:34 AM
xDARKNIGHTx's Avatar
New User
it's the mount's u gotta change them
Old Jun 3, 2009 | 08:10 AM
scspeed's Avatar
I have filled inserts though
Old Jun 12, 2009 | 01:49 PM
masijdm's Avatar
i have the same problem with my b20vtec i dont know if its the mounts the whole dash and door shakes crazy
vtak2nr
May 31, 2007 12:07 PM
rattlecanjoe
Feb 16, 2007 12:48 PM
turbotime
Oct 4, 2005 05:18 AM
quickergixxer
Jul 4, 2005 11:12 AM
j87w
Feb 3, 2005 06:15 AM
