Please help! Car wont start!!
Old May 12, 2009 | 06:15 PM
NVMYDC's Avatar
Default Please help! Car wont start!!
okay...heres the story..i was comin home from the varsity meet in atl ga, and right when i made a left into my neighborhood..my car shuts off..doesnt spudder doesnt bogg, just shuts off. i try to crank it..it just turns no crank, so i fill up half way w gas (was on 1/4 tank) and try again..still no crank just turns and turns and turns. next i checked the spark, got spark. so i rolled the car down the hill and popped the clutch, car starts! but jst shuts right back off after rpms drop. ive reset my timing, made better, new battery, made better, new starter, made better, i tried my fuel pressure , its there, i tried basically everything except pull out my injectors and see if they spray, tried my ecu, grounds, timing,sparks, oil,gas,starter,battery, everything, the car just turns but doesnt crank and if i jst hold it on turn it slowly dies...any suggestions anyone? PLEASE this is my daily driver to work and school and i am really really stuck..please help h-t family
ps: motor is obd1 b18c1
Old May 13, 2009 | 07:28 AM
NVMYDC's Avatar
Default Re: Please help! Car wont start!!
bump anyone please help
Old May 13, 2009 | 08:36 AM
LOVEthatDC2's Avatar
up
Old May 13, 2009 | 09:06 AM
majik2457's Avatar
New User
When your car died the first time it Just shut off? Me and my friend were driving on the Interstate one time and her car Idled at a low rpm and then shut off. then when we tried to start it again all it did was turn. sometimes after waiting a bit we got the engine to turn over but it would die instantly. they told us the octane level was to low and the gas we were driving on was almost like water. so id say check your Octane level. make sure water didnt leak into the gas tank some how through the gas cap. and if it is that water somehow got into the engine well im not a mechanic so I cant really help you there. but atleast i gave you a direction :D hope it helps
Old May 13, 2009 | 02:22 PM
NVMYDC's Avatar
thanks for your advice i will be checking that out also anyone else? bump!
Old May 13, 2009 | 09:07 PM
jdm_bones's Avatar
You said timing is good, and spark is good...well that leaves only fuel....what kind of fuel pressure did it read...sounds like low fuel pressure, change your fuel filter see what that does for you.
Old May 14, 2009 | 01:18 AM
sp00ledbseries's Avatar
start with a fuel filter
Old May 14, 2009 | 07:38 PM
NVMYDC's Avatar
checking fuel filter tomrorow! thanks for your help guys!
Old May 14, 2009 | 07:52 PM
arrocha87's Avatar
also do u hear ur fuel pump prime when u turn the ignition on? ur fuel pump/fuse/clip might have gone out...
Old May 15, 2009 | 06:22 PM
NVMYDC's Avatar
did all t hat...car still wont start!! bump!!
Old May 15, 2009 | 06:33 PM
jdm_bones's Avatar
Please make a video...and post it, I want to hear the fuel pump prime, and the main fuel relay click, and I want to hear the engine, as you attempt to turn it on! Only then would I be able to help!
Old May 15, 2009 | 07:43 PM
1badcrx's Avatar
I would think it has to be fuel related... if you have a chilton's or any other manuel follow the diagnostics
Old May 15, 2009 | 08:26 PM
Ramon96LS's Avatar
Check rotor in cap!
Same happened to me and my rotor was broken!
I panicked like you!
And that was the last thing I checked too haha!
Old May 15, 2009 | 09:18 PM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by Ramon96LS
Check rotor in cap!
Yea check your rotor first i almost bet its off! it happens! then check tps sensor check the voltage it could be off and give starting issues as well.
Old May 16, 2009 | 08:32 AM
Master23's Avatar
Also check out this starting troubleshooting guide:
http://www.garage411.com/Starter
Old May 16, 2009 | 10:55 AM
NVMYDC's Avatar
thanks to all..at work right now waiting for bus to go home..will check when i get there thanks all
Old May 18, 2009 | 04:45 PM
NVMYDC's Avatar
check rotor cap button dizzy, checked fuel related , checked started checked everything!!! everything is fine!wtf is the problem here! no cel no nothings! please any other help would be greatly appriciated
khoalizzle
Sep 10, 2008 10:51 AM
vtec420kingH22
Nov 17, 2006 07:39 PM
Audio28
Jul 3, 2003 05:33 PM
sounique
Apr 16, 2003 04:23 PM
