Ls turbo or gsr turbo
Old Aug 18, 2002 | 12:44 AM
silverEH2's Avatar
Default Ls turbo or gsr turbo
wrong screen name again paul...i would never make a lame post like this
Modified by silverEH2 at 5:20 PM 4/13/2004
Old Aug 18, 2002 | 11:36 AM
DIRep972's Avatar
Smarter than you
Default Re: Ls turbo or gsr turbo (silverEG6)
I went 13.3 @ 104 in a basically stock revhard kit on a bone stock LS motor in a 2600lb integra. before I went turbo I went 16.0 @ 86 w/ IE so it made a 2.5seconed difference for me. only upgrades ive made after the kit were 3" exhaust, BFG drag radials, and an ACT clutch.
ive raced alot of GSR turbos and pulled off better ET's many times. usually the mph is around the same too. I would tell u to stick with the LS motor and boost it to about 11psi. in a CRX w/ revhard kit on an LS at 11psi and slicks i could definitly see that going 11's.
Old Aug 18, 2002 | 11:49 AM
bullz's Avatar
Default Re: Ls turbo or gsr turbo (DIRep972)
Cheaper and better motor to boost. LS Save $
Old Aug 19, 2002 | 06:56 PM
SIK IN DA HED's Avatar
New User
definitely keep the LS and boost it.
Old Aug 19, 2002 | 08:32 PM
97hb's Avatar
Yes on the LS.
Old Aug 20, 2002 | 07:45 AM
DevinW's Avatar
LS...cheaper and easier to find if you happen to blow the engine.
Old Aug 20, 2002 | 10:52 AM
jinxproof99's Avatar
New User
Default Re: Ls turbo or gsr turbo (iLLestjr)
the LS is cheaper and a good motor for boost, but it is not better than the gsr.
[Modified by jinxproof99, 2:53 PM 8/20/2002]
Old Aug 22, 2002 | 02:22 PM
dohcsideSi's Avatar
Default Re: Ls turbo or gsr turbo (jinxproof99)
thank you....maybe they will listen to you
Old Aug 26, 2002 | 01:33 PM
krazn's Avatar
the LS is better for forced induction...not the gsr... LS has a bigger bottom end...stick w/ ur ls
Old Aug 26, 2002 | 01:37 PM
New User
Default Re: Ls turbo or gsr turbo (krazn)
they must have some good *** crack in philly this month.
Old Aug 26, 2002 | 04:14 PM
97hb's Avatar
lol
Old Aug 26, 2002 | 04:39 PM
tygsr's Avatar
Default Re: Ls turbo or gsr turbo (97hb)
gsr turbo all the way...
Old Aug 26, 2002 | 09:17 PM
BoM's Avatar
BoM
Default Re: Ls turbo or gsr turbo (tygsr)
vtec haters
Old Aug 27, 2002 | 11:31 AM
93LSivic's Avatar
My philly *** crack goes 12 sec on stock street trimmed LS'd civic.
Old Aug 28, 2002 | 09:26 AM
hydroflip's Avatar
Default Re: Ls turbo or gsr turbo (93LSivic)
LS is a great platform for boost...gsr is alot better but the ls is what i would go for.
Old Aug 28, 2002 | 02:48 PM
BoM's Avatar
BoM
Default Re: Ls turbo or gsr turbo (hydroflip)
another ls turbo to whoop soon...........
Old Aug 29, 2002 | 09:12 AM
hydroflip's Avatar
Default Re: Ls turbo or gsr turbo (BoM)
non vtec haters...hehehe...we dont need no stinkin vtec damnit!
Old Aug 29, 2002 | 09:41 AM
B00STeD's Avatar
vtech 0wnz joo!
Old Aug 29, 2002 | 10:22 PM
Ri5e's Avatar
Default Re: Ls turbo or gsr turbo (B00STeD)
F*ck the LS, B20 OwNz Jo0! J/P
Old Aug 31, 2002 | 11:40 AM
lazy bum shaughn's Avatar
Only reason LS is better to boost is becuase the motor is like 2 grand cheaper than a GSR. If price wasn't an issue I'd turbo an R.
Old Aug 31, 2002 | 04:03 PM
Drew Peacock's Avatar
Default Re: Ls turbo or gsr turbo (Mixxed Bboy)
Well you can run more boost reliably on the LS with out resorting to super expensive tuning devices, and as stated if you blow it an LS is going to be cheaper and easier to find.
Old Sep 1, 2002 | 09:56 PM
HybridKOOP's Avatar
Default Re: Ls turbo or gsr turbo (turbozxi)
Sorry guys.. I'd rather run 1 - 1.5psi less on the GS-R longblock (due to SLIGHTLY higher compression) and gain about 45-50hp over the LS that is able to run a whole nother pound or so of boost because of a half point less compression.
Old Sep 1, 2002 | 10:01 PM
D-Man's Avatar
Default Re: Ls turbo or gsr turbo (HybridKOOP)
yes,the GSR you gotta go with,its simple,better flowing head=more HP than any LS will put out.
Old Sep 1, 2002 | 10:28 PM
Default Re: Ls turbo or gsr turbo (D-Man)
Put out more HP at what cost? you can boost an ls upto 12psi with only average tuning I doubt you would go past 10 on a GSR without great tuning . So they would be producing the same kind of power.
Old Sep 2, 2002 | 08:10 AM
New User
you can see 280-300 hsp on pump gas on a stock gsr. its pretty difficult to do that with an ls. plus, the difference in rev limit alone makes the gsr the better motor. 8200 vs 6900. not to mention the flow of a gsr head over a ls. gsr.
kirby_lys
Sep 13, 2006 07:08 PM
kirby_lys
Sep 13, 2006 07:27 AM
lsracer27
Apr 9, 2004 08:12 PM
Audi A4
Jun 6, 2002 03:10 AM
GSR
Apr 30, 2002 07:38 PM
