Noise, TO bearing hmmm, can't pin it
Old May 12, 2009 | 03:23 PM
Redwidow's Avatar
Icon6 Noise, TO bearing hmmm, can't pin it
one thing after another with this car, Car ran perfectly fine before changing the head gasket because my FAL fan failed and Dam straight slightly lifted the head. So I replaced the HG slapped it all back together and when i rev it up it on the drop back down some where from the car seems to have a dry grind it some times continues while at idle but goes away. Sounds a lot louder from underneath the car near the flywheel. I do not think it is any bearings or cams. I pulled the alt and PS already not coming from either. I have a CC twin disc clutch on the car but I could not find a video or find how they sound when they go out. I have very low miles on the car and can't make out what else the noise could be. My trans is a LS with OBX Diff. Like I said car ran perfectly fine before i parked it just to fix the minor heating up issue, this is fixed car wouldn't climb past 165 for 30 mins of idling maybe the E85 but serious it use to get hot pretty fast when not having the heater running. Ok Im rammbling too much DR pepper. If anyone might have suggestions for me let me know I'll try and get a clean video to see if you can hear what im talking about. Thanks
PS still not friendly with the search feature
Old May 12, 2009 | 04:09 PM
philafelman's Avatar
Default Re: Noise, TO bearing hmmm, can't pin it
check the pulleys on the t-belt...water pump, idler pulley....and im not sure if you can check like this, but if you could spray something on the t.o. bearing through the inspection shield and see if it changes tone, might be worth a shot without taking the trans. out.
Old May 12, 2009 | 04:18 PM
Redwidow's Avatar
I'll get a video up hopefully it captures the noise, I think if it were the water pump or idler pulley it would make constant noise and it does't and no way to get to the TO bearing with out droping the trans but want to 100% mark that as problem if I drop it out. I'll work on that video shortly.
Old May 13, 2009 | 01:01 PM
Redwidow's Avatar
Upon todays start up it was sqealing like this and if you listen close you can hear the grind as the rpms drop it lightly catches it in the video. I'm charging my camera because the battery died and I'll get another vid up shortly. Thanks!
http://s9.photobucket.com/albums/a71...t=MOV01178.flv
Old May 13, 2009 | 01:03 PM
Redwidow's Avatar
Old May 13, 2009 | 01:04 PM
Redwidow's Avatar
Firefox is better than Explorer ...
Old May 13, 2009 | 03:15 PM
Redwidow's Avatar
i guess no one knows huh?
gstrudler
Transmission & Drivetrain
12
Mar 24, 2014 10:52 PM
civicb16eg
12
Jan 30, 2007 12:21 PM
Desperado
Apr 23, 2006 12:38 AM
aka Paco
Apr 23, 2006 12:36 AM
BudMan
Aug 11, 2004 04:58 AM
