Track Pads?
Old May 12, 2009 | 02:04 PM
MilanoRedDC2's Avatar
Default Track Pads?
Factory ITR Brakes and stainless braided lines. Any suggestions for Buttonwillow Raceway #13CW?
Thanks
-Uly
Old May 12, 2009 | 02:12 PM
Mashimaro's Avatar
Default Re: Track Pads?
Motul dot 5.1 or RBF600 if you have money, Project Mu MAX500 pads all around. that's what i have
there's more hardcore pads out there, but i'm happy with these so far as i hardly track compared to daily driving.
Old May 12, 2009 | 02:18 PM
Stinkycheezmonky's Avatar
Suspetise...
What type of tires and experience do you have?
Old May 12, 2009 | 02:57 PM
slofu's Avatar
Carbotech AX6 front pads and ATE Brake Fluid should work well with sticky street tires.
Old May 12, 2009 | 03:42 PM
alexs2200's Avatar
I have used Motul RBF600, Brembo Blank disks, and Endless CC-X pads (now called MX-72) Pads are excellent track pads that can drive on the street w/o noise. Pricey for pads but do not fade and can handle high temps 500 plus degrees. There are other cheaper pads out there with same amount of bite but chances are they will also warp your rotors going back and forth from street use and track use. These Endless I've had on for more than a year. Tracked and street w/o disk warp or noise. Dust is another story...
RockinaRHard's Avatar
Best question to answer with.
Old May 12, 2009 | 03:49 PM
98itRspec's Avatar
Thanks
-Uly
Are you gonna be there @ the 30th of this month?
Old May 12, 2009 | 06:36 PM
nsxtasy's Avatar
H-T Order of Merit
I've used Endless CC-X pads on my ITR, and found that they squealed pretty loud on the street.
Old May 12, 2009 | 10:39 PM
Yes sir. Registered for Saturday and Sunday.
I am running Bridgestone RE-11's in a 205/45/16
This will be my first time at the track. I currently have EBC Green Stuffs all around.
Old May 13, 2009 | 03:01 AM
Suspetise...
You Cali guys, is that track/configuration hard on brakes? Any longish straights to cool them down?
I'm leaning towards Hawk HP+, mostly because you're a noob and on street tires. There are other options available to you though.
Old May 13, 2009 | 03:07 AM
irev210's Avatar
I thought you had reds up front? Those should be okay... I've never used them, so I would be curious to see how you liked them, but they should handle the heat. The green stuff will definitely fade though.
Greens will fade, so will Hawk HP Plus, especially at buttonwillow
If you are going to go with carbotech, I would get the XP10 up front, AX6 in the rear.
Old May 13, 2009 | 03:24 AM
Suspetise...
XP10s + street tires + noob sounds bad to me... The Cobalt CSRs might work better than HP+, but I have no actual experience with them. If not those, maybe Cobalt XR4s?
Old May 13, 2009 | 05:06 AM
irev210's Avatar
I've never used Cobalt, can't comment. I can say that the HP+ will fade without much effort at buttonwillow. the CSR and XR4's have much higher operating temps, closer to hawk blues.
Why do you say XP10 + street tires + noob sounds bad? They are nice pads...
for brake fluid, the ATE superblue is really cheap, offers good value. $12 for 1L
Old May 13, 2009 | 06:42 AM
Suspetise...
I don't personally like them, but that's not the issue really. They're race pads, with a pretty strong bite. Strong bite and street tires is generally not good (fairly easy to lock up the tires), and with a noob who doesn't brake well, it'd be even worse.
Old May 13, 2009 | 06:45 AM
get RIGHT's Avatar
I agree. And this way he doesn't have to change his pads out. They are great on the street too. A nice all around pad.
Old May 13, 2009 | 06:54 AM
nsxtasy's Avatar
H-T Order of Merit
Yup. Another vote for the HP+.
The only time I've gotten the HP+ to fade is when the pad is brand new, and not bedded properly. They call this "green pad syndrome", when the pads fade the first time (sometimes the second session also) they get really hot. After that, they should be fine, without fading, for the remaining life of the pad.
This has been true of every kind of street pad and street/track pad I've ever used on the track.
The Motul RBF600 gives you a lot more protection against boilover. The extra $15-20 for a full flush isn't going to break the bank. That's a no-brainer for me.
Old May 13, 2009 | 07:10 AM
alexs2200's Avatar
Did you install them with all the brake shims and/or bed them in after installation? I can tell you I'm on them right now and my S2k is on them w/o noise. I believe if you leave out the shims squealing may occur. These are my 6th set between the S and the ITR. No problems here.
Old May 13, 2009 | 09:07 AM
irev210's Avatar
I only ran the HP+ once, dunno more than what I experienced with them - it was fairly unfavorable... I will definitely run them again, they are just stored away for now.
On the hawk blues, I was still having issues with fading (got worse as the number of track miles went up) and they obviously are much more track oriented, fade resistant pads
After 473 track miles + 100's of street miles on the hawk 9012 blues, the pads still had life left, but the rotors are starting to crack. I am replacing the setup with XP10's, hopefully more rotor friendly for me. My friend runs the XP10 on his S2K (and ran them w/ street tires) with very favorable results, no strange brake modulation issues, or having issues with too strong of an initial bite.
I will tell you that the blues eat rotors, there is a fairly hefty ridge on my rotors, but I did drive these cold, frequently. Outside of the mild dusting, they were quiet and a great street pad.
For fluids, ATE is pretty awesome. They make the super blue and the type 200 (same fluids, just different colors). It is nifty for when you are bleeding your brake setup. As soon as your flush goes from blue to gold (or vice versa) you know you are 100% flushed.
12 bucks for 1 liter
http://www.tirerack.com/brakes/ate/a...blue_fluid.jsp
http://www.tirerack.com/brakes/ate/a...e200_amber.jsp
# Boiling point minimum: 536 degrees F
# Wet boiling point minimum: 388 degrees F
VS Motul (20 bucks a 1/2 liter)
dry boiling point of 593F and a wet boiling point of 420F.
I would assume you have much bigger issues going down if you are boiling brake fluid running ANY sort of dual purpose street/track pad or even a mild track pad. Besides, you are better off buying the cheaper ATE and changing it more frequently.
No doubt that Motul is better, but so is the castrol :-/
Old May 13, 2009 | 12:49 PM
nsxtasy's Avatar
H-T Order of Merit
I've gone through a lot of sets, maybe 5-10 sets. They've worked fine for me.
That's not what "rotor friendly" means. Some pads are more abrasive than others, meaning that they wear down the thickness of the rotors. That has nothing to do with cracking. With track use, any front rotors will eventually crack, in my experience, no matter what pads you're using, and before they get particularly thin.
And as far as fluids go, a difference of 57 degrees F in the boiling point is very significant. The ATE is okay, but the Motul is just better, plain and simple. I'm happy to pay the extra $15-20 per year for the extra insurance. To me, it's a no-brainer to get the Motul rather than the ATE. Brake fluid is not a place where I worry about saving a small amount of money.
Old May 13, 2009 | 01:19 PM
trifenix's Avatar
i wish i had motul at the event...
i had sticky tires
porterfield r4s pads (good for track and street imo...i will try axxis ultimates next time to compare)
new rotors
stock dot 3 fluid ftl.
and my fluid gave up.....that **** is scary when approaching a turn.
at the end of the day:
tires chunked and slightly greasy
pads were good no squeals
rotors were blue
brake fluid failing so spongy brakes.
Old May 13, 2009 | 01:26 PM
racebum's Avatar
the ultimates or hp+ would be a great starting pad.
motul 600 is great fluid. why run anything else?
if you can fade the above pads i would avoid the black/blues and go right to the ht-10 up front. your ultimates and plus's will probably still be fine out back. at least i would try that split and see how it works before you spend the money on track pads for both front and rear. the only thing you have to be careful about with the really high temp pads is vaporizing the rubber booty around the caliper piston. i guess careful is the wrong word to use since it basically just happens.
personally, i love ultimates for a street/autocross pad. as far as open lap day goes? i'll know sometime this summer when i get a chance to lap day @ PIR.
Old May 13, 2009 | 02:54 PM
Suspetise...
Ultimates are a step below HP+'s, and will fade with track use. And trifinex man, that was just a bad call on using stock fluid
Old May 13, 2009 | 03:39 PM
irev210's Avatar
heh, yes - however there is a rather large amount of rotor missing, you should see the lip on my rotors, fairly significant. I know rotors will always crack, it is the frequency of cracking that I am trying to get down. My whole point is, more metal, less heat, less heat, less expansion, less expansion, less cracking. Hawk blues are not nice to rotors, they dont squeal, and worked pretty well though.
Old May 13, 2009 | 04:01 PM
nsxtasy's Avatar
H-T Order of Merit
As for fluid - with that logic, it is only an extra $15 to go with the castrol SRF... nothing wrong with either choice. Unless you are running very aggressive race pads, your pads are always going to fade before the fluid boils.
Motul is okay, but the Castrol SRF is just better...
WRONG. The dry boiling point is what matters on a tracked car. And the dry boiling point of Motul is better than the Castrol SRF (593F vs 590F). So in the case of Castrol SRF, you're getting zero benefit for a higher price.
your brake pads you are running are ALWAYS going to fade before your fluid will boil, ATE, Motul or Castrol SRF.
Also WRONG. Which fails first depends on the pads and the fluid.
Old May 13, 2009 | 04:49 PM
irev210's Avatar
I actually found the spec, it is over 600F, thought I don't know how official it is. Even their website says "in excess of 300C"
Definitely agree with you on that one, I was talking about premium fluids (ate superblue/type200, motul 600, etc) and street/track pads (HP+) or mild track pads (blues, xp10,xr2, etc)
