Confused about ACL D series main and rod bearings
Old May 12, 2009 | 08:23 AM
hovic's Avatar
Default Confused about ACL D series main and rod bearings
Hi..
I´m building a D16Z5 engine for my buddy and I´ve got a few issues with the ACL rod and mai bearings. Please take a look at the attached pics:
here you can see the main bearing already installed in the girdle. Why is there a groove for the tang on both sides. The bearing itself has only one tang.
This is one of the rod caps (stock rods) There´s a oil hole in the bearing but the rod cap doesn´t have a oil hole so what is this good for?
same issue with the main journal in the block
The discription on the acl packages says theese bearings are for aso for D16Z engines so I assume I have the correct bearing.
I already plastigaged the bearings and ALL the mains are at aprox. .0019". It´s a bit to loose in my opinion. What do you thing?
Old May 13, 2009 | 05:37 AM
hovic's Avatar
Default Re: Confused about ACL D series main and rod bearings
bump
Rocket
Jun 22, 2005 11:56 AM
Importracer_001
Oct 31, 2004 11:35 AM
IN VTEC
Nov 23, 2003 09:13 PM
Sonny
Aug 23, 2002 08:06 PM
