FS: Built B16A Block, B16A Head, Turbo Parts...
All prices do not include shipping. PM me for a shipping price. I will consider trades for nice 17"+ 5 lug wheels plus or minus cash on my end depending on what they are and what you want. No Rotas/Drags/etc.
- Built Turbo B16A Shortblock - This is a complete short block. The only thing missing is a water pump and timing belt. This is an OBD0 block that has been decked .010in. and the cylinder walls have been slightly overbored for the use of forged pistons. With a B16A head, this is a 9.31:1 motor. As far as mods go, it has JE 10.0:1 81mm Flat-Top Pistons (218902a), Crower 4340 Steel Billet Connecting Rods w/ Crower Rod Bolts (B93744B-4), ACL Race Series Rod and Main Bearings, Golden Eagle Oil Squirter Block-Offs, B16A Oil Pan tapped with a Stealthmode Return Line Fitting, Golden Eagle Head Studs, mFactory Oil Block Adaptor, Stealthmode -3AN Stainless Steel Feed Line, Stealthmode Restrictor Valve, OEM Honda S2000 Oil Filter, all new gaskets throughout the entire block, oil pump was speced out and has OEM clearance with brand new hardware, thermostat works perfect, brand new timing belt tensioner. THIS IS BUILT TO BE TURBOCHARGED! DO NOT ASK IF YOU CAN RUN THIS N/A! There is just around $2,000 in work to this block.
$1,000
- B16A Cylinder Head - Completely stock. Includes Camshafts, Cam Gears, Cam Caps and Covers, and VTEC Solenoid. DOES NOT INCLUDE Valve Cover, Distributor, or Intake Manifold. The head has two studs, one for the intake and one for the exhaust manifolds, that are broken off in the head and will need to be drilled out. Has new VTEC solenoid gasket and screen. Otherwise, its perfect and will come with new valve seals, cam seals, and intake/exhaust gaskets.
$500
- Hydro B-Seires ACT 6-Puck Clutch, Pressure Plate and OEM B16A Flywheel - Used and in great working order. Clutch Disc Has some life left on it.
$150
- OBD1 B16A Distributor - Complete and in great working order.
$100
- B16A2 Intake Manifold w/ NextGear Thermal Gasket - Bare Intake Manifold with under 1,000 miles on it.
$25
- B16A Intake Maifold, Fuel Rail, FPR and Throttle Body - Includes all sensors except for IACV. No injectors.
$50
