B18C throws CEL then no power? help please
Old May 11, 2009 | 08:22 PM
dpstang98gt's Avatar
New User
Default B18C throws CEL then no power? help please
Well i got a GSR JDM B18C OBD1 in my 96 hatch that is fully rebuilt with just over 300 miles on it now. It runs perfect and very strong until it gets warmed up then the CEL comes on and it starts running like total crap? The guy that rebuilt it for me said it was the knock sensor code. So i replaced the sensor but still no luck. So what are my options? Someone said i may be able to get it chipped to bypass the sensor? is that the only way i can get around it, or is there a easier and cheaper way to do it? thanks for any help
Old May 11, 2009 | 08:27 PM
MONSTERek4's Avatar
Default Re: B18C throws CEL then no power? help please
well if it is fully built im guessing it has aftermarket pistons so u will throw no because gas is burning differently so u need to modify the ecu if u are in the socal area i can do it for you with crome
Old May 11, 2009 | 08:39 PM
New User
whoops im sorry i mean it is totally rebuilt with all new pistons, rings, rods...etc, all the stock stuff.
Old May 11, 2009 | 08:40 PM
MONSTERek4's Avatar
what codes are you throwing
Old May 11, 2009 | 08:48 PM
New User
im not really sure when i went to autozone they have to shut the car off to check it, and as soon as you shut the car off the cod goes away. but the guy that rebuilt it said it was a knock sensor code when he checked it.
Old May 11, 2009 | 10:20 PM
MONSTERek4's Avatar
try plugging a stock p28 that would eliminate the code just to make sure it is that if u replace the knock try wiring it direct to the ecu its on ly one wire
Old May 12, 2009 | 10:21 PM
New User
does anyone know of a cheap way to bypass the code?
Old May 13, 2009 | 04:49 AM
mtber's Avatar
Chip the ecu to disable the knock sensor.
Old May 13, 2009 | 02:52 PM
MONSTERek4's Avatar
he said cheap i dont think chipping jis ecu falls under cheap unlike wiring the knock straight to the ecu
Old May 13, 2009 | 11:46 PM
New User
what do u mean wire it to the ecu? i dont understand i thought it was already wired to the ecu?
Old May 15, 2009 | 04:49 AM
MONSTERek4's Avatar
i had the same problem with my ek and it turn out the pin was mest up
EgB18c406
Jun 1, 2015 05:24 PM
mac51o
Mar 1, 2011 11:18 AM
DrazoYU
Aug 15, 2005 08:54 PM
Mashimaro
Feb 15, 2005 01:28 AM
wizzards581
Nov 6, 2003 07:53 PM
